Author Topic: auto trans ?  (Read 1836 times)
drunkencityworker
auto trans ?
« on: July 16, 2009, 08:37:12 AM »
pretty sure i have 30rh. doesnt want to shift into 3rd till rpms are way up there. besides fluid level whatelse can i check. or is this begining of the end. fluid isnt burnt.
Re: auto trans ?
« Reply #1 on: July 16, 2009, 09:18:35 AM »
Drop the pan and check/change the filter. Look for metal shavings/gunk/mud. Been in any water lately? Other than not being burnt how does the fluid look?
Re: auto trans ?
« Reply #2 on: July 16, 2009, 08:12:06 PM »
BTW, if you end up needing a rebuild let me know. I know a couple guys just north of the border in Kenosha.
drunkencityworker
Re: auto trans ?
« Reply #3 on: July 16, 2009, 09:40:12 PM »
I disconnected the bat to erase memory and it was a bit better. my bud said fluid looked thin. guess i will drop the pan. thanks for heads up jj.
drunkencityworker
Re: auto trans ?
« Reply #4 on: July 17, 2009, 08:39:26 PM »
got some new fluid and filtr. going to drop tomorrow. are there any vacum or senors i should check while in there?
drunkencityworker
Re: auto trans ?
« Reply #5 on: July 18, 2009, 02:35:00 PM »
changed fluid and filter. got a little better. then worked it up and down block in 4low for a bit and now all better. knock on wood. thanks
Re: auto trans ?
« Reply #6 on: July 19, 2009, 05:29:58 PM »
Good to hear.  :thumb:
