Author Topic: mounting bracket for coolant reservoir and power steering  (Read 1383 times)
cletz97
im looking for one to buy cause im putting in an electric fan.
where can i find one for 97 tj?
i found one on quadratec but idk if its right heres the link
http://www.quadratec.com/products/17800_100.htm
any help would be greatly apreciated
and if needed i could make one if anyone has any good ideas.
thanks
Offline VA_YJ
  • Now I need a CJ...
Re: mounting bracket for coolant reservoir and power steering
« Reply #1 on: July 29, 2009, 01:47:23 PM »
If you have some sheet steel, a drill, a hammer, and a vice, it shouldn't be too hard to fab one.  If you have a metal bending brake, that's even better than the hammer and vice.  You can make a template out of cardboard or some thin metal to get the dimensions and holes correct.
cletz97
« Reply #2 on: July 29, 2009, 05:48:39 PM »
does anyone have any pictures or plans for a bracket?
or any links?
« Reply #3 on: July 31, 2009, 05:15:26 AM »
For all you folks with a TJ doing this fan conversion have any of you priced a Jeep fan shroud for a 2.4l engine? It has a nice shroud that will mount a fan and will fit your radiator the wiper reservoir from one of those should bolt right on the fender
