Author Topic: Detroit locker rebuild  (Read 3428 times)
DiGGeR77
« on: July 29, 2009, 09:29:09 AM »
I was giv'n a free detroit locker for my d44, of course its stripped out and needs rebuilt. The guy said he broke an axle and kept driving on it until it stripped out. I need to tear it apart to find out what It needs. If I take out the allen bolts, is it spring loaded (am I going to get hurt)? Any place to get replacement parts other from the factory?
Re: Detroit locker rebuild
« Reply #1 on: July 29, 2009, 10:53:18 AM »
Use some allthread, washers, and nuts. Install the allthread and tighten the nuts.Make sure you have a short side and a long side of the allthread. Then remove the allen bolts. When you back off the nut from the all thread do the long side.
The parts must be had thru Eaton. Randy's or 4wheel parts, or any diff shop that carries Eaton products can get the parts. IIRC they are in the $250 range.
When you fix it put it back together the same way. That spring is a bugger without the allthread!
DiGGeR77
« Reply #2 on: July 29, 2009, 11:55:06 AM »
Thanks fourbanger, I knew you would know!
