Author Topic: Shackled!  (Read 2796 times)
  • 4BangerJP.comŪ Donator
Shackled!
« on: August 05, 2009, 10:44:49 PM »
I thought I ordered front/rear 1" shackles about a month ago; the rears were boomerangs.  I get the rear boomerangs and they look ok.
After waiting around for a couple of weeks I started to figure out that I must not have ever ordered the fronts (no financial record of the order and like a dumb@$$ I seem to have deleted the  email receipt I could have sworn I had received).  So I do another order for standard 1" shackles.  But I ended up with this situation which I wasn't expecting.
I have rear boomerangs that are 3/8" thick and then I have these new standard versions for the front that are apparently 1/4" thick (thickness wasn't mentioned and should have asked).  Both sets have poly bushings, greasable and Grade 8 hardware.   I am inclined to send these 1/4" standard shackles back.  You think it matters all that much?  Not having much luck finding 1" lift standard shackles 3/8" thick with grade 8 hardware.  :brick:
Top shackle is rear boomerang, bottom is front shackle
(And you coil spring guys can receive my most sincere  :twofingers:)   kidding  :lol:
« Last Edit: August 05, 2009, 10:49:53 PM by chrisfranklin »
Re: Shackled!
« Reply #1 on: August 05, 2009, 11:21:03 PM »
It's kind of odd that they make the REAR thicker; most of the weight (engine, winch...) is in the front of a Jeep!
Re: Shackled!
« Reply #2 on: August 05, 2009, 11:25:50 PM »
It's two different brands.  A few minutes ago I ordered some Rough Country 1" inch standard versions that are supposed to be 3/8 like the boomerangs -- which I also believe are Rough Country.  So the 1/4" setup is going back
Re: Shackled!
« Reply #3 on: August 06, 2009, 11:59:41 AM »
When  got my boomerangs, I ordered the matching front set from Currie.
These came with greasable bolts and poly bushings.  I am very happy with them.
Felipe
Re: Shackled!
« Reply #4 on: August 06, 2009, 12:57:55 PM »
The standard is 3/8" and 1/4".  My fronts are 1/4" and the rears are 3/8", it's not a big deal.
Re: Shackled!
« Reply #5 on: August 06, 2009, 02:08:45 PM »
I didn't think it was that big a deal.  I was planning on refraining from using the added center bolt for these front/rear 1" shackles, so it seemed like the thicker 3/8 version was the way to go.
Re: Shackled!
« Reply #6 on: August 06, 2009, 10:43:33 PM »
Yet when wheeling the majority of the weight transfer is to the rear.
Re: Shackled!
« Reply #7 on: August 12, 2009, 02:27:14 PM »
@jfrabat
Those front set from Currie looks good...
How much did you pay for those?
I bought those a LONG time ago!  I have no idea what I paid for them...
That makes sense...
Offline rcrovo1
    • scuba lessons by me
Re: Shackled!
« Reply #8 on: August 16, 2009, 02:03:32 PM »
Hey yjjeeper i have a set of standard currie front shackles that i would be willing to let go for 50.00 shipped to cont usa. i replaced with a set of curries tow shackles so i can flat tow my jeep. The hardware and bushings are all new as i reused the hardware and bushings when i installed the tow shackles.
1995 YJ 2.5L, 4in RE susp., 33x12.50 mtr, 4.0L TB, TB spacer, 4.88 gears, borla header, magnaflow catback, highflow intake, warn 9000#, lock-right up front
Banshee600
Re: Shackled!
« Reply #9 on: August 20, 2009, 04:37:36 PM »
What is a tow shackel look like ? I'm looking for shackels and I also flat tow mine
Re: Shackled!
« Reply #10 on: September 04, 2009, 10:57:44 PM »
