Author Topic: Firepower Ignition Kit Question  (Read 4165 times)
TA-YJ
« on: August 06, 2009, 11:59:27 AM »
I was looking at picking up the firepower ignition kit for my 92 YJ, but I had a question.  I have a 92 so I will need the adapter for the coil.  Has anyone installed the adapter kit?  It seems like it would be kind of a hack and splice job for something as important as ignition.  Links to the install instructions would be great if anyone has them also.  Thanks a lot.
Re: Firepower Ignition Kit Question
« Reply #1 on: August 06, 2009, 12:02:57 PM »
I would go with the Performance Distributor system many of us run; it allows you to run a .060" gap no problem...  Screaming Demon Coil, LiveWires, and rotor and cap are included in the 2.5L kit.
« Reply #2 on: August 06, 2009, 01:42:58 PM »
Um, the Firepower Kit is by Performance Distributors.
I don't know what adapter he's talking about though.  There is one for TJ's I think but the YJ shouldn't need one.
*Looked at the PD website and it states there is an adapter BUT I never used one and I have a '92.  Mine's is the pre-production kit that all of the other 2.5L's are based on.
« Last Edit: August 06, 2009, 01:45:34 PM by Jeffy »
TA-YJ
« Reply #3 on: August 06, 2009, 02:31:04 PM »
Thanks for the quick replies.  I Guess I will go ahead and order it w/o the adapter and see if I need to order it when it gets here.  The one for the TJ looks like a nice piece, but the one for the YJ just has those quick splice clips that I assume youre supposed to clip into your ignition wiring.
« Reply #4 on: August 06, 2009, 09:06:41 PM »
Well DUH!  I feel dumb now!
Anyway, mine did not use an adapter either, and it's a '94...
TA-YJ
« Reply #5 on: August 06, 2009, 10:37:37 PM »
Haha no worries.  Only 91-92 and 98-99 needed adapters.  Hopefully mine will be like Jeffys and not need an adapter.
« Reply #6 on: August 07, 2009, 12:07:11 AM »
Sent PD an email asking them about it?  Unless they changed the coil I don't see why it's needed.
andrew383
« Reply #7 on: August 07, 2009, 08:01:00 AM »
i bought the coil,cap/rotor but skipped on the wires,there just to much.I went with a good set of Accels from summit :)
TA-YJ
« Reply #8 on: August 07, 2009, 10:46:30 AM »
I sent them an email a while back.  I wanted to know if the 2.5 needs the adapter even though only the 4.0 is listed as needing it.  The responder said they were "pretty sure" the 2.5 needed it too.  I guess well wait and see if it does need one or not.  I can always just order one after the fact anyway.
« Reply #9 on: August 07, 2009, 01:58:36 PM »
Well, since I know the owner, I can ask him if you really want to know.
« Reply #10 on: August 07, 2009, 10:12:15 PM »
I just added this to my list of "cheap" upgrades.
« Reply #11 on: August 08, 2009, 08:26:02 AM »
I like my FirePower kit, but be sure to use lots of dialectic grease on the wires, they seem to pull apart pretty easily.
TA-YJ
« Reply #12 on: August 08, 2009, 11:56:57 AM »
If you could ask him that would be great.  If there is an adapter needed, Im curious as to what the differences are between your coil and the ones that must come with it now that need an adapter.
TrailsLessTaken
« Reply #13 on: August 11, 2009, 02:03:38 PM »
Mine is a '91 and I didnt need an adapter for mine
« Reply #14 on: August 11, 2009, 04:06:55 PM »
I talked to PD and he said there has been no change so you should be fine without the adapter.
