Author Topic: Installed a 4.0 TB Check Engine light now on  (Read 3485 times)
Moondo
« on: August 11, 2009, 03:53:34 PM »
I had to replace an exhaust manifold stud this weekend so i figured it would be a good time for the 4.0 throttle body upgrade. I used all of the 2.5 TB components and I have double/triple checked all of my connections. After install I disconnected the battery and let it sit overnight. The jeep idles just fine but there is a slight hesitatition when I really get on the excelerator. Should I continue to disconnect the battery to try and reset or did I miss something?
Re: Installed a 4.0 TB Check Engine light now on
« Reply #1 on: August 11, 2009, 04:59:17 PM »
What code is it throwing?
« Reply #2 on: August 11, 2009, 06:10:57 PM »
x2.
also make sure you didn't mess the vacuum lines. Could be the tps too (from the hesitation you describe), but since it was running fine before it's unlikely
Moondo
« Reply #3 on: August 12, 2009, 08:25:47 AM »
I will be installing a Supertrapp exhaust next week I will check the codes at that time. In the meantime I will check vacuum lines and TPS.
Offline justin399
« Reply #4 on: August 12, 2009, 09:14:12 PM »
Make sure you swapped the AIS housing to, this is the piece that the AIS sensor bolts into. I swapped the sensors but not this housing and had troubles. Good luck.
93 YJ:2.5l aussie's front & rear, 4.0TB & spacer, hand throttle, 19lb injectors, no trackbars, ramsey 8.5e.
« Reply #5 on: August 12, 2009, 10:01:44 PM »
Just wondering if you bored the intake out to 62mm?
« Reply #6 on: August 12, 2009, 11:51:37 PM »
what's the AIS housing? are you referting too idle control valve? (i don't know what AIS is - just curious)
Offline justin399
« Reply #7 on: August 13, 2009, 12:49:49 PM »
Check this out from Jeffy: http://4bangerjp.com/forums/index.php/topic,8.msg8.html#msg8
Look at where the AIS motor bolts in, thats the housing. When you swap the throttle body you've got to use the 2.5L sensors and that 2.5L housing. I hope this helps.
« Reply #8 on: August 13, 2009, 01:00:40 PM »
yeah, that's the idle valve - i didn't know it's called AIS, seen it as IAC (idle air control) - good to know that is also called AIS (air idle ?something? i assume), but that's correct you need the motor and the housing.
dos0711
« Reply #9 on: August 14, 2009, 03:56:33 AM »
Actually, no you don't. I used a 4.0 throttle body as is. The only problem I had was it was a tad slower to come down to idle. That being said, on my 2nd TB swap I did use the 2.5 IAC but if I were to do it again, I'd prbly leave it 4.0 as it didn't make a huge difference. When I initially started up the complete 4.0 the idle raced up to about 3k for about 20 seconds. But after that, the pcm brought the idle down to normal.
Moondo
« Reply #10 on: August 19, 2009, 10:45:14 AM »
I didn't bore it out to 62MM and I used the AIS housing as well as sensor. I have been driving it everyday for the past two weeks since I did the swap and I noticed that I was gaining pickup and the hesitation went away just this past weekend but the light remained on. Well, Last night I stopped to pick up another can of throttle body cleaner. I planned on taking the TB apart again and go through all of the sensors and make sure everything was tight with no leaks. When I started the jeep to leave the store the light was off! When I came into work this morning it was still off... Now I am wondering if I had a piece of crud or something when I originally did the swap. Do I go ahead and pull it apart or just drive it?
« Reply #11 on: August 19, 2009, 12:36:09 PM »
I vote for just driving it if it is working fine.
« Reply #12 on: August 19, 2009, 06:02:52 PM »
we still didn't hear what the code is so it could be unrelated (like o2 for example)
Moondo
« Reply #13 on: August 20, 2009, 08:54:30 AM »
I didn't get a chance to check the code out. I will get that done and post it.
