Author Topic: im having fuel problems  (Read 2018 times)
fokai
« on: August 19, 2009, 02:31:48 AM »
my fuel pump turns on but have no fuel coming out of my tb injector.....i can start it but it'll only idle.but,when throttle it,it just dies out.can anybody please give me some info?THNX...........
Re: im having fuel problems
« Reply #1 on: August 19, 2009, 05:16:55 AM »
Check the fuel pressure, kinda sounds like the pump is toast
« Reply #2 on: August 19, 2009, 10:57:16 AM »
like he ^ said or you've got some dirt blocking the prefilter. Also wouldn't hurt to check/replace the filter too if you didn't do it in a while. As long as the pump is spinning these are pretty much the issues that can prevent the flow of gas (bad pump, pre-filter, filter).
fokai
« Reply #3 on: August 20, 2009, 11:01:36 PM »
thnx alot guys i really appreciate it.i'll try it out..whats the average pressure supposed to be?thnx
« Reply #4 on: August 20, 2009, 11:03:40 PM »
sorry, i have no idea what the press on the tbi is - hopefully one of the guys here knows and will help
« Reply #5 on: August 21, 2009, 06:18:05 PM »
TBi needs 14.5psi at the injector (aka after fuel presure regulator) i think the pump is soposed to push at abut 17psi.. i could be wrong on the pump pressure as i could only find the injector pressure in my manual...
