Author Topic: what is this?  (Read 3747 times)
Re: what is this?
« Reply #15 on: August 21, 2009, 06:52:36 PM »
this is a guess but i think it's just a plug to not have water dripping on the starter - i think that hole is for factory handling during machining process - they need pilot holes to align and fix the block solid during the bore-out process of all the precision areas for the crank, cam, cylinders (but i can't tell for sure, so don't take the plug out :D)
Re: what is this?
« Reply #16 on: August 21, 2009, 06:56:48 PM »
why would they have a plug to prevent water from dripping on the starter when oil dumps on it when you take the oil filter off??? but you could be right
« Last Edit: August 21, 2009, 06:57:01 PM by chardrc »
BarneyJeep
Re: what is this?
« Reply #17 on: August 21, 2009, 07:27:26 PM »
its not in any kind of channel...i tried to pull it out and nothing came out, couldnt get the plug out either....almost like it was attached inside the block.
Re: what is this?
« Reply #18 on: August 21, 2009, 09:47:12 PM »
i dunno then, i've seen those holes on other blocks too but no plugs on them
