Author Topic: Stupid Jeep  (Read 11901 times)
0 Members and 9 Guests are viewing this topic.
Re: Stupid Jeep
« Reply #45 on: September 17, 2009, 10:32:02 PM »
It actually will take the digital signal and convert it to other PPS so it can calibrate your speedometer without changing the gear.
cool, good to know
Re: Stupid Jeep
« Reply #46 on: September 17, 2009, 10:33:25 PM »
Forgot about that part. When I was on 35's and 4.88's my speedo was off a few miles per hour. I didn't worry about it. Then I went to 37's and 5.38's and it reads just about perfect within a mile per hour. I didn't touch the box so I'm glad it worked out.
 I guess Moz doesn't like his speedo reading 100  :lol:
« Last Edit: September 17, 2009, 10:39:57 PM by FourbangerYJ »
  • Poseur Extraordinaire®
Re: Stupid Jeep
« Reply #47 on: September 18, 2009, 06:36:27 AM »
Yep...I have a super short SYE...no speedo gear...have been running 10% fast for a year and I'm sure that doesn't help any.
Figured, while I'm ripping into everything, might as well fix that.
Picking up a ton of shrink connectors as well as the tape to get everything as high and tight as possible....stupid lights look like they won't be here until Monday though.... :fitz:
Re: Stupid Jeep
« Reply #48 on: September 18, 2009, 02:25:28 PM »
I run the Dakota Digital interface due to the supershort SYE, and I like to run different size tires to the trail and back.
Re: Stupid Jeep
« Reply #49 on: September 18, 2009, 02:54:54 PM »
Any install tips??
I guess I should mount it right behind the dash or near the cluster....any help would be appreciated as I don't want to spend 1/2 a day figuring out which wires I need to splice in and from where.
Re: Stupid Jeep
« Reply #50 on: September 18, 2009, 03:20:04 PM »
Any install tips??
I'd mount it near the dash.  You don't want to expose the box to the elements.  Not to mention, you won't have to climb under the Jeep to reset it.
« Last Edit: September 18, 2009, 03:20:47 PM by Jeffy »
Re: Stupid Jeep
« Reply #51 on: September 18, 2009, 05:34:52 PM »
I mounted it under the dash, below the steering wheel.  I can reach up and adjust the speedo up or down on the fly.  It is spliced into the speedo wires at the speed sensor mounted to the transfer case.
I had to play around with the 4 switches to dial in the correct setting, I will take a look tomorrow and see where my 4 switches are at.
Re: Stupid Jeep
« Reply #52 on: September 18, 2009, 05:56:06 PM »
I was more interested in how you wired it and where....so you just ran the wires down under the Jeep to the t-case??
