Author Topic: Stupid Jeep  (Read 11225 times)
0 Members and 14 Guests are viewing this topic.
Re: Stupid Jeep
« Reply #30 on: September 15, 2009, 10:03:27 PM »
hmmmm...someone on Pirate mentioned that the clockspring might be the issue...stupid Jeep....
sorry for this question and just for my reference - what is the clockspring?
Offline Mozman68
  • Poseur Extraordinaire®
Re: Stupid Jeep
« Reply #31 on: September 16, 2009, 06:43:50 AM »
It's behind the steering wheel....it has been known to cause some false TPS related readings since they share some wiring (maybe just the ground??)...yet another wire to check....just need to pull the steering column shrouds off and make sure everything is clean.
I still think it might be the CPS...will have the dealership check it out.
Re: Stupid Jeep
« Reply #32 on: September 16, 2009, 12:53:24 PM »
Hmm, I'm going to with that as well.  You might try taking the steering column apart and cleaning up the clock spring's connections.
Offline Mozman68
Re: Stupid Jeep
« Reply #33 on: September 16, 2009, 01:34:43 PM »
It really is very strange....starting up from my other office at lunch, Jeep is sputtering...speedo going whacko as usual....voltage is fine......then the voltage drops to 12...and then down to nothing....what a pain in the ass....stupid Jeep.
Need to get this taken care of before I head to IN next week.
Offline aw12345
    • my jeep picture page
Re: Stupid Jeep
« Reply #34 on: September 16, 2009, 02:19:00 PM »
The clock spring is known to short voltage to the TPS when it fails.
Don't really think that is your problem, your problem or problems are somewhere else.
When it acts up you need to do some prodding with a volt meter you have a bad connection somewhere most likely due to corrosion. Remember you live is the road salt area of this country your gremlin could be in a multitude of places but it is related to either powers or grounds
2006 Jeep Wrangler TJ SE
2004 Jeep Wrangler TJ SE
Offline Mozman68
Re: Stupid Jeep
« Reply #35 on: September 16, 2009, 08:52:37 PM »
Did you ever just stand back and look at something differently and have an incredible moment of clarity???
The guy was backing my Jeep up after changing the oil and I noticed my back-up lights (the ones in my LED lights) were not on...and then I remembered one of the times when my cluster was whacko and I had an issue with my lights as well.
So...I'm riping out the lights this weekend and doing a complete re-wire....amazing what a short will do....
Re: Stupid Jeep
« Reply #36 on: September 17, 2009, 08:21:34 AM »
didn't you say you just rewired them on page 1 post 1?  :wall:
Offline Mozman68
Re: Stupid Jeep
« Reply #37 on: September 17, 2009, 07:33:17 PM »
Yeah...I suck....and the fact that all of the rear wiring is exposed because of my flat fenders doesn't help either.
New lights are coming probably tomorrow...
Going  :wall: to wire and wrap the living hell out of them this weekend....and then ordering new back up lights....LED as well.....
« Last Edit: September 17, 2009, 08:29:31 PM by Jeffy »
Offline Mozman68
Re: Stupid Jeep
« Reply #38 on: September 17, 2009, 07:38:17 PM »
...and I also ordered this as well....
Re: Stupid Jeep
« Reply #39 on: September 17, 2009, 07:50:51 PM »
good luck.. wiring always sucks...
Re: Stupid Jeep
« Reply #40 on: September 17, 2009, 08:29:17 PM »
LOL!  I actually like wiring.  Although, I did almost become a Electronic Tech.   :lol:  Just make sure you practice soldering and use shrink tubing.  You don't want to use crimp on connectors and you don't want to do cold solder joints.  Those are the main problems.  Then tie up the wires with zip-ties to kee them from moving around.  You can wrap them with electrical tape, but I then to shy away from it since it looks bad and collects dirt.
Re: Stupid Jeep
« Reply #41 on: September 17, 2009, 09:03:07 PM »
they also have the paint on electrical coating... but i don't know if i realy like it.. i have problems with getting even coverage.. it tends to like to glob and be effected by gravity before drying.. shrink tubing is the way to go...
Re: Stupid Jeep
« Reply #42 on: September 17, 2009, 09:42:34 PM »
what's the plan with this one? oh, and what does it do?
Re: Stupid Jeep
« Reply #43 on: September 17, 2009, 10:00:56 PM »
That's what I run to convert the cable signal from the T-case to electronic signal for the speedo.
Why do you need it?
Re: Stupid Jeep
« Reply #44 on: September 17, 2009, 10:16:58 PM »
It actually will take the digital signal and convert it to other PPS so it can calibrate your speedometer without changing the gear.
