Author Topic: Hood scoops  (Read 5147 times)
Re: Hood scoops
« Reply #15 on: September 28, 2009, 11:11:56 AM »
If you pull the grill and cover off the cowl youll find a plastic "bucket" under there that is very flimsy. It can get misaligned and the water will go past it. I just had to push mine to the correct position and problem solved. I think a stick had gotten through from a limb and pushed it to the side. When I was running a woods trail.
If you have water on both sides its often the windshield gasket between the frame and tub.
thanks, i'll give it a shot.
Re: Hood scoops
« Reply #16 on: September 28, 2009, 07:42:19 PM »
i think i have my leak issues sorted but i need some help from you guys. passenger side is from the upper part of the window-its a half door and i just put in a new top and uppers, the gasket wasnt pressed hard enough against the frame-i bent it a bit back and now it should solve that.  as for my DRIVER side leak-last rain storm i tracked the water trail which runs forward close to-but not against-the left side of the body, all the way forward near the firewall. there seems to be a plug a few inches above that area. anyone know where this leads to or what could be causing the water to drip down there? this is on the drivers side.
