Author Topic: Hood scoops  (Read 5146 times)
Tsd
Hood scoops
« on: September 15, 2009, 01:52:24 PM »
Hi folks!
I´m ordering some stuff from Quadratec and I want to buy a hood scoop to prevent rain from getting in through the cowl vent and wetting my passenger carpet, I had that "old wet dog" smell all winter long  :uhoh:. There are many options and I wanted to know if anybody has any experience with them or has heard anything from them.
These are some of the options:
Bushwacker
Rampage
http://www.quadratec.com/products/13006_602.htm
Truckmaster (in black)
http://www.quadratec.com/products/13006_11.htm
Rugged Ridge
http://www.quadratec.com/products/13106_003X_PG.htm
Any opinions are welcomed, thanks in advance! :wave:
Re: Hood scoops
« Reply #1 on: September 15, 2009, 01:56:02 PM »
I have one like the Rampage one shown. Helps nicely with the heat but can't use it now that the windshield is down when I wheel. You can have it for $20 shipped if you want it.
Re: Hood scoops
« Reply #2 on: September 15, 2009, 04:56:18 PM »
or you could unclog the drain and keep your feet dry... although the truckmaster on doesn't look half bad.
drunkencityworker
Re: Hood scoops
« Reply #3 on: September 16, 2009, 05:45:50 AM »
pull the carpet and open the drain plug. other wise the old friend mr rust is gonna be paying you a visit. just my 2cents
Tsd
Re: Hood scoops
« Reply #4 on: September 16, 2009, 12:05:16 PM »
Is it black? Do you accept paypal?
I always make sure that the drain is unclogged, but somehow rain always finds a way into my carpet, I thinks it's my jeep just being a jeep :lol:
Yeah, everytime the carpet gets wet I remove it and put it in the sun etc. I'm just tired of worrying if it's going to rain and drying the carpet   :mad:
Thanks for the replies!
Re: Hood scoops
« Reply #5 on: September 16, 2009, 12:52:50 PM »
Yes and yes, shoot me a PM with your address and I'll give you my paypal addy.
Re: Hood scoops
« Reply #6 on: September 18, 2009, 07:06:48 PM »
Hi folks!
you're getting rain in from the cowl??!! how exactly is that possible. after it rains im ususally left with a nice puddle directly infront of either my passenger side or driver side seat. i thought it was my soft top given that it was torn and such, but when driving in the rain i never noticed it leak in from around the windows etc. Anyway, i replaced the top and the other day noticed a puddle in front of the driver seat. i figured the upper skins werent seated correctly, weather strippin wasnt tucked all the way in..so i fixed that. now that i think of it, when i noticed the puddle, the inside of the door and around it was dry. could the rain be coming in from the cowl? is a scoop the only way to fix this?
Re: Hood scoops
« Reply #7 on: September 19, 2009, 07:51:04 PM »
where are the drains located. how does water come in through there and will a scoop fix it or will unplugging the drain work?
Tsd
Re: Hood scoops
« Reply #8 on: September 20, 2009, 03:35:24 PM »
Found this picture at jeepforum:
The drain is the tube that is bent down.
« Last Edit: September 20, 2009, 04:04:21 PM by Tsd »
Tsd
Re: Hood scoops
« Reply #9 on: September 20, 2009, 03:41:20 PM »
I don't know if it is the only way to fix it, I know Chrysler put a cover on the heater box on 2002+ models. I have read that a scoop helps a lot. You can get that cover for 50$ on ebay. If you search "water on passenger side floor " on google or any jeep related forum you will get a lot of solutions.
BarneyJeep
Re: Hood scoops
« Reply #10 on: September 20, 2009, 03:51:32 PM »
chrysler also had a TSB for earlier TJ's..the drian points straight out and the wind from under the jeep will push water back up through the drain, they have a "retro fit" kit that puts a piece of plastic 90* hose on it so it points at the ground.
Re: Hood scoops
« Reply #11 on: September 20, 2009, 05:31:10 PM »
so if it's a drain issue water will only collect on the passenger side. i get water on both sides....sometimes its just driver or just passenger, sometimes both.
Re: Hood scoops
« Reply #12 on: September 20, 2009, 07:52:18 PM »
i only get water on the driver's side (95 YJ) - there used to be a lot, but i fixed the seal between the cowl cover (i think that's the name, the sheetmetal where the cowl vent goes) and the windshield lover (EDIT: please read LOWER and not lover  :english:) frame (not the frame around the windshield, the body part under that) using some urethane sealer (similar to the winshield urethane but a little more flexible) - i had to dig out the old sealer that cracked, did it on about 1/2 the length from the vent all the way down to the fender - it was pouring thru there. Now i get drops, not much like 1/3 of a coffee cup when it rains overnight - it's not from there where i sealed it, i can't figure out where it's coming from - i also put silicone on the weather strip under the windshield frame but still get it. my drains are clean and they flow well) i put the hose in there. If anyone knows where this can come from i'd appreciate a couple of pointers (drives me nuts, like i said,   not much but it sucks).
« Last Edit: September 20, 2009, 07:53:49 PM by sharpxmen »
Tsd
Re: Hood scoops
« Reply #13 on: September 20, 2009, 10:04:58 PM »
When my scoop arrives i'll post an update on my flooding problems  :thumb:
I am an ignorant on YJ's, so i'll leave the subject to the YJ gods.
« Last Edit: September 20, 2009, 10:08:43 PM by Tsd »
Re: Hood scoops
« Reply #14 on: September 28, 2009, 09:25:05 AM »
If you pull the grill and cover off the cowl youll find a plastic "bucket" under there that is very flimsy. It can get misaligned and the water will go past it. I just had to push mine to the correct position and problem solved. I think a stick had gotten through from a limb and pushed it to the side. When I was running a woods trail.
If you have water on both sides its often the windshield gasket between the frame and tub.
