Author Topic: Electric Fan switch  (Read 1916 times)
TA-YJ
Electric Fan switch
« on: September 25, 2009, 07:00:29 PM »
Im starting to gather parts for an electric fan swap into my YJ and was going over switch options.  Rather than using the standard probe type switch, I was wondering if there is any place on the block/radiator to use a thermostatic switch to run off the temperature of the actual coolant.  If there is not an open space, is there an area where it is easy to accommodate one (like a T fitting, etc)?  Thanks for the help.
czjeeper
Re: Electric Fan switch
« Reply #1 on: September 28, 2009, 10:14:54 AM »
What I plan on doing is splicing in a short piece of steel tube into the upper radiator hose.
This will have a bung welded in that is tapped for the therm. switch I use.
« Reply #2 on: September 28, 2009, 11:13:12 AM »
you can buy those ready made (seen some on ebay at decent prices).
czjeeper
« Reply #3 on: September 28, 2009, 03:28:41 PM »
Got a link?
