Author Topic: Electric Fan  (Read 3402 times)
Offline mrcabinet
Electric Fan
« on: September 27, 2009, 01:24:18 PM »
I'm still debating whether to go the lazy route and go with a flex-a-lite complete kit (I have a credit at 4wheel parts that would cover over half of it) or do the Taurus with a DC controller, which would cost about the same but require making brackets, etc. Then I read on another forum that an e-fan from an '04 - '06 2.4l TJ will bolt right up and have the coolant and PS mounts. Has anyone tried this?
Re: Electric Fan
« Reply #1 on: September 28, 2009, 09:06:29 AM »
Have not tried the TJ, but I would go with FoMoCo and DCC.  It will pull less amps (soft starts) and can pull more air if needed...  FoMoCo can move up to 4,000CFM, and I think Flex-a-lite is something like 2,700CFM IIRC.
Offline mrcabinet
Re: Electric Fan
« Reply #2 on: September 29, 2009, 09:12:24 AM »
Yeah, I think I'm gonna scrap the '04-'06 TJ idea. The only used one I could locate is in Kentucky for $100.00 plus shipping. The stealership wants $525.00 for a new one! Plus, I'd still have to get the DC controller and the connector for the fan.
Re: Electric Fan
« Reply #3 on: September 29, 2009, 10:11:47 AM »
My FoMoCo Taurus fan was a whopping $28 at the U-Pick...  You can run it off a relay for about $50 until you can get the DCC box...  Mine keeps the 4-banger cool even in low speed, so no need for a huge relay.  I actually have a relay to turn on the low speed, the DCC attached to the high speed, and a 3 position switch to choose which one to use (so I have AUTO, OFF, ON) and if the DCC controller ever fails out in the trail (which I doubt, because it has worked flawlessly so far) I have a redundant system to keep my engine cool.
Re: Electric Fan
« Reply #4 on: September 29, 2009, 10:35:20 AM »
The only two 'brackets' I had to make for my Taurus fan was taking two small L brackets, easily found at the hardware store, and bending them so the ends are a little farther apart.  Then one side attaches to the fan shroud and the other to the OEM hole in the radiator support.
Being a TJ, you may need more to support the PS reservoir and coolant overflow bottle.
jdarg
Re: Electric Fan
« Reply #5 on: September 30, 2009, 09:26:24 AM »
1600 cfm seems to work fine for me even on those 98 degree windless days stuck in traffic. No shroud either. Probably could have gotten by with even less.
Get a controller that ramps up the fan speed when it starts. I didn't and my idle stumbles for a split sec whenever it kicks on from the inrush current.
« Last Edit: September 30, 2009, 09:28:32 AM by jdarg »
i_offroad
Re: Electric Fan
« Reply #6 on: October 07, 2009, 04:31:33 PM »
I picked up a fan for $15 and a handfull of oem 70amp relays for $10 at my local pick a part. I have mine wired High Off Low, I would like to get a good controller one of these days.
Offline mrcabinet
Re: Electric Fan
« Reply #7 on: October 08, 2009, 01:41:55 PM »
I know, the FoMoCo fan sounds like the best bet - plentiful and cheap. It's just that I've had a very poor track record with Ford products over the years, plus the thought of a fan out of something as ugly as a '95 Taurus going into this jeep appalls me. Maybe if I refer to it as a Lincoln fan I'll feel better.
Re: Electric Fan
« Reply #8 on: October 08, 2009, 02:32:33 PM »
They have a solid track record in everything from hot rods, to 4x4's.  BTW: the Lincoln fan MK 8 is not the same as the Taurus fan.
Re: Electric Fan
« Reply #9 on: October 08, 2009, 02:54:38 PM »
They are not?  I thought they were...  I guess this is why I get myself into trouble!
Re: Electric Fan
« Reply #10 on: October 08, 2009, 04:12:01 PM »
They're similar but not the same.  The motors have different pn# IIRC.  Then you have the size of the fan, 16" vs 18"
Re: Electric Fan
« Reply #11 on: October 08, 2009, 08:30:26 PM »
the lincoln motor is also bigger (and higher amps as well) and flows more cfm but it is oversized for the 2.5L - even at 1/2 speed should still have plenty of flow for the 4 banger (i think at full speed it is over 4000cfm if i remember correctly)
