Author Topic: Rear drive shaft off an '85 on a 93YJ?  (Read 1791 times)
lqdtrance
« on: October 02, 2009, 06:13:49 PM »
Will an '85 rear drive shaft work for a 93YJ? what is the length of driveshaft needed for a 93 YJ w/ a 4" lift?
Re: Rear drive shaft off an '85 on a 93YJ?
« Reply #1 on: October 02, 2009, 06:24:58 PM »
Dana 300 was a fixed yoke on the 85, NP231 was a slip yoke on the 93. Won't work even if the length is OK.
lqdtrance
« Reply #2 on: October 02, 2009, 06:25:42 PM »
damn. thanks for the quick reply.
« Reply #3 on: October 02, 2009, 09:59:43 PM »
 :thumb:
« Reply #4 on: October 03, 2009, 01:53:59 AM »
You should be able to reuse the stock driveshaft if you installed a transfer case drop with the lift kit.  Many jeeps vary so it's best to measure your application to get the correct driveshaft length.  I've got a ton of Wrangler driveshafts if you know the length you need.
« Reply #5 on: October 03, 2009, 08:03:51 PM »
Really? Got any fronts? My spline is worn pretty bad.
« Reply #6 on: October 04, 2009, 03:35:28 AM »
Rears only, sorry.
lqdtrance
« Reply #7 on: October 13, 2009, 01:42:12 PM »
Cool. I'll let you know. Right now my computer just crapped out.
