Author Topic: Something is wrong  (Read 1736 times)
newjackyj
Something is wrong
« on: October 04, 2009, 07:31:30 AM »
My yj is leaning towards the drivers drive and i have no idea what I bent. Please forgive the rookie question but I am stuck, HELP
Re: Something is wrong
« Reply #1 on: October 04, 2009, 08:16:53 AM »
check the leaf springs, shackles and frame - see if something is broken or bent. how much is it leaning?
Offline 95 Lowbuck
« Reply #2 on: October 04, 2009, 08:20:31 AM »
Could be alot of things,
Check to see if it is a bent spring usually around attachment points.
Check for a bent shock that restricts travel.
Check the shackles to make sure they let the spring work freely.
Try to compare all these components to the good side.
newjackyj
« Reply #3 on: October 04, 2009, 08:29:09 AM »
Its about 3/4 of inch off. The springs and shackles appear to be the same on both side and only about 6 months old.  In the event it is the frame where wouldyou get that fixed?
« Reply #4 on: October 04, 2009, 10:05:14 AM »
i don't think it's the frame unless you hit something hard, it won't bend otherwise. i was asking about it to check if the mounting tabs for the leaf springs and shackles are not broken bent badly. the YJs are known to have differences between left/right side mine is somewhere under 1/2'' difference, but if you just change the leafs i would contact the place you bought them from, my bet is on one of the springs sagging.
« Reply #5 on: October 04, 2009, 12:14:52 PM »
It's your springs, they're sagging a bit uneven.  It's common to see a slight difference between the driver and passenger side.
« Reply #6 on: October 04, 2009, 02:24:06 PM »
Mine never sat level until I got some custom made springs. You can try and swap sides to see if the lean goes the other way, then you'll know it's the springs or not.
