Author Topic: 4Banger Jeep Speed (Ha! :)  (Read 31341 times)
  • 4BangerJP.comŽ Donator
Re: 4Banger Jeep Speed (Ha! :)
« Reply #45 on: October 24, 2009, 09:47:43 PM »
Speaking of 4Banger Jeep Speed, Jp magazine is showing a Turbo 4 cylinder in their latest newstand issue.  Didn't see who was making it -- must be  a project.
« Reply #46 on: October 25, 2009, 07:37:30 PM »
sorry man but you're wrong , the timing on the Jeep is controlled by the PCM on a predefined map (a table, not the map sensor) - it uses inputs from sensors to calculate the advance timing based on rpm, map sensor reading, tps and i think the IAT. the table is stored on 2 dimensions rpm and vacuum (map reading) and i think the tps and IAT come in play to adjust the predefined advance. not sure if the coolant temperature is used or not for the Jeep but i believe i saw somewhere that is used on some vehicles. You are right about some v8 distributors that you can rotate them to change the initial advance and also change the weights and/or springs to adjust the curve - all late ECUs use an advance map and calculations to determine the correct degrees of ignition advance though.
you can do it like Jeffy said by changing the cps position which will basically tell the PCM that the TDC is at a different location than it actually is - the downside with that is that you might get out of sync with the cam sensor but i'm not sure what the difference would be to affect the PCM so it could be safe. I don't know on top of my head what the diameter of the flywheel is on the 4banger but guessing here if let's say it is 20'' then you will need to move the CPS about 3/16 of an inch (0.1875'') to get 1deg change in advance - for that it should be fine but if you want to retard or advance the ignition like 4 degrees that can be a problem since you'll run out of room on the bellhousing opening (you'll need to move the cps 3/4'').
dude I'm not going to argue if you think your right whatever. i'm a licensed tech and my jeep doesn't have variable valve timing or spark timing the only adjustments the pcm in my 95 yj has is fuel timing and length of timing. That's it. Honda "vtec" and other manufactures in newer engines have variable valve timing and spark timing. you can't control spark timing in a distributor unless you move it or have some kind of mechanical advance built in to the distributor witch my yj doesn't. if the pcm changed the spark timing it would make no difference due to the rotor isn't in contact with the distributor cap prongs. the coil can't discharge the energy unless it has somewhere to go.  In terms it would short out the coil.
« Last Edit: October 25, 2009, 07:40:00 PM by Torch_Ind »
  • Chief Squirrel BlowerŽ
« Reply #47 on: October 25, 2009, 09:37:53 PM »
dude, first off i am saying the same thing regarding the inability of adjusting the timing by moving the distributor, so there's no point in an argument there, but read my post again and you'll see that's what i meant (including the quote from you to which i replied - here it is:
Quote from: Jeffy on October 22, 2009, 01:13:03 PM
Timing isn't controlled by the distributor.
yes it is. why do you think people with performance v8's advance the distributor for more high end output and they call it advancing the timing!!!
they also had centrifugal weights in the older distributors to advance timing at higher rpm!!
if you don't believe me take the distributor out and try to move the rotor while holding the gear - it will not move. Now do the same on a points one and it will move - the ignition advance will vary even though the position of the rotor will not change in relation to the TDC of the cylinders it fires the spark to, so when you have 10 deg advance in timing the rotor won't move forward 5 degrees to compensate.
the rotor is never in the contact with the prongs, and no it will not short out the coil, you can test that by removing the wire from the coil to the center of the dist cap, crank the engine and see what happens, then put it back on and it will start with no problems.
Anyway, whatever (like you said), i'll quit trying to explain since you are a certified tech and we are not.
EDIT: It is explained even in the Jeep Factory Service Manual that you can download from the FAQ section on this site
under general information of the fuel system (page 19 in file 95xj_14.pdf) you can find this
"The PCM is a preprogrammed, dual microprocessor digital computer. It regulates ignition timing, air-fuel ratio, emission control devices, charging system, speed control, air conditioning compressor clutch engagement and idle speed. The PCM can adapt its programming to meet
changing operating conditions"
and also this right under the one above
Powertrain Control Module (PCM) Inputs represent the instantaneous engine operating conditions. Air-fuel mixture and ignition timing calibrations for various driving and atmospheric conditions are preprogrammed into the PCM. The PCM monitors and analyzes various inputs. It then computes engine fuel and ignition timing requirements based on these inputs. Fuel delivery control and ignition timing will then be adjusted accordingly"
on page 31 in file 95xj_14.pdf, section Fuel system component description/System operation - under the engine startup mode section it states "The PCM determines the proper ignition timing according to input received from the crankshaft position sensor"
under engine warm-up mode you'll also find this "˛ The PCM adjusts engine idle speed through the idle air control (IAC) motor and adjusts ignition timing"
and on the next page (page 32 in the same file) it says "The PCM adjusts ignition timing by increasing and decreasing spark advance" and further down under cruise mode "The PCM adjusts ignition timing by turning the ground path to the coil on and off"
- i believe the official service manual to be correct (and it is the same for most modern engines, not just for Jeeps). copy/paste from the manual below
« Last Edit: October 25, 2009, 10:12:19 PM by sharpxmen »
« Reply #48 on: October 25, 2009, 10:27:45 PM »
the one thing you are correct about is that the rotor metal needs to be as close as possible to the dist cap prongs - for that matter, since the rotor does not move with the ignition advance that metal portion at the end of the rotor covers about 20 deg, if you look at old style distributors with centrifugal advance the rotor has a smaller metal end (covers about 5 deg) and you guessed right that they need to be aligned, they never touch but are very close, there is a spark there as well as the spark plug and if you watch an engine running at night or in the dark on some distributor caps you can actually see the sparks under the cap
this was so I am fair, got a bit thrown off by the way you answered in the reply and i felt that i wasn't all nice in mine either
  • Servicing Squirrels Since 1995Ž
« Reply #49 on: October 26, 2009, 09:39:18 AM »
http://www.505performance.com/
The turbo kit came from these guy's.
« Reply #50 on: October 26, 2009, 06:22:43 PM »
  Not to mention, the contacts are large and do allow for a few degrees of advance or retard.  I don't think you can go more then a few degrees without then getting out of sync with the mechanical's.
It's surprising to see anything from them.  They brought out their first kit several years ago then did nothing with it.  I see they have a 2.5L pictured with the turbo.  $3000 is a lot though.
« Reply #51 on: October 26, 2009, 06:37:23 PM »
pretty much translated in 1/2 the degrees to the dist since it's 1 full rotation for every 2 crank rotations
$4,550 for the JK supercharger (centrifugal procharger unit) kit only with FMU (no fuel/timing ECU) - quite expensive.
$5,100 for the turbo kit with Accel Fuel management and Intercooler - $3,900 for the DIY kit with the same intercooler and Accel ecu but still high priced since you need to fab everything else.
I wonder how many of these they actually sell.
« Reply #52 on: October 26, 2009, 07:40:18 PM »
I highly doubt they sell more then 5 a year if that.  I forgot that they made a kit since they do not advertise.  I think the only other company to make a kit was Turbo City but they stopped as they didn't want to get CARB Certification and it was already a slow seller.
Offline mrcabinet
« Reply #53 on: October 28, 2009, 10:16:55 AM »
You can't go wrong with Bounty Hunter's 62mm throttle body and spacer. Just remember to grind or bore the intake manifold. The difference it made on mine was substantial.
C.Redbeardd
« Reply #54 on: October 28, 2009, 01:15:03 PM »
Haha. I remember getting mine up to 66mph once! ha
« Reply #55 on: October 28, 2009, 02:09:25 PM »
who carries the gears? i am fine now but i want to get a 39T in case i ever go to 35s. and how much is one if you remember.
I have a bunch, let me know what you need.  If I don't have it, I recommend www.tacomaspeedometer.com .  Cheap and ship fast.
« Reply #56 on: October 28, 2009, 02:11:12 PM »
i think i need the 39T for 35s and 4.88s, but i need the short version (YJ '95)
« Reply #57 on: October 29, 2009, 11:09:06 AM »
29,30,33,34,35,37 is all I have, seems the 39 and 41 are pretty popular with the lower gearsets.  The long shaft/short shaft are interchangeable, just swap the gear onto whichever length shaft you need.  I would highly recommend Tacoma Speedometer at the above link.
I would also recommend this Universal Speedometer Signal Interface from Dakota Digital, pretty cheap ($80) and can adjust your speedo for any tire size or gear ratio, and for any drivetrain/ECM combination for that matter.  I run one, works great as I run two different sizes of tires between my road and offroad tires, adjusting the speedo is just a few pushes of the button below the dash.  I also HAD to run one since I installed a super-short SYE and it no longer uses a speedo gear.  http://www.dakotadigital.com/index.cfm/page/ptype=product/product_id=126/category_id=287/home_id=59/mode=prod/prd126.htm
vprsrul
« Reply #58 on: October 31, 2009, 08:22:03 AM »
with 33/12.50's and stock gearing (no speedo correction either) I can only maintain 45mph in 5th which is roughly 53mph after correction.  In 4th gear I can maintain 60-65mph on the speedo or about 70-75mph corrected but it sucks down some gas at that speed.  This is all at about 1/2 to 3/4 throttle input with one to two passengers and no load.
« Reply #59 on: October 31, 2009, 09:24:31 PM »
I put in the 38 tooth today and it worked fine right off the bat.  There's a little metal bump at 6 o'clock on the VSS port opening on the transfer case.  You just apparently need to line up your teeth-range numbering on the VSS -- mine was 31(2?)/38 -- directly over that little metal bump and you're all set.  I also put in a new gasket, then reset battery.  Feels like its driving better already.
« Last Edit: October 31, 2009, 09:25:35 PM by chrisfranklin »
