Author Topic: Pitman Arm  (Read 12329 times)
Re: Pitman Arm
« Reply #15 on: October 28, 2009, 11:03:52 PM »
Sorry guys but I am pretty new to this. Can you tell me what purpose the shackle reversal has. Sorry Jeffy if you already told me in another post.
http://jeep.off-road.com/jeep/article/articleDetail.jsp?id=260281
Offline mrcabinet
Re: Pitman Arm
« Reply #16 on: November 03, 2009, 07:57:34 AM »
Here's a pic of the front end. The trackbar / draglink angles are pretty close, but not perfect. It looks like about an 1 1/2" drop on the pitman would be better. And, what about the angle of the tierod coming off the draglink?
Re: Pitman Arm
« Reply #17 on: November 03, 2009, 08:19:59 AM »
i think the drop pitman arm would correct that as well - but yeah, doesn't look right. i think you need more than 1.5'' if that's on the vertical just b/c the steering box shaft is at an angle, but hard to tell how much from that pic
Steve-0
Re: Pitman Arm
« Reply #18 on: November 03, 2009, 08:48:37 AM »
It looks like one end of your tie rod is reversed, but that wouldnt work either. Is it that relocating bracket you have there? What is that? High steer? This set-up looks odd to me. But its a TJ right?
« Last Edit: November 03, 2009, 08:52:17 AM by Steve-0 »
Re: Pitman Arm
« Reply #19 on: November 03, 2009, 08:51:37 AM »
good catch
Steve-0
Re: Pitman Arm
« Reply #20 on: November 03, 2009, 10:49:15 AM »
Why is his tie rod twisted like it is? And What is that relocating bracket for? That damper shock is mounted to it. Weird. I see he has a track bar and looks like at least lower control arms. I have none of this stuff plus a nasty drag link angle and my bump steer is bad when I hit the brakes. It goes to the right pretty bad. But not to the left that much unless I am on a whoop road that forces my suspension downward. That straightens out my steering wheel until the suspension retracts again.
Re: Pitman Arm
« Reply #21 on: November 03, 2009, 11:57:55 AM »
This steering setup is a Inverted-Y (TJ) as opposed to a Inverted - T (YJ).
Re: Pitman Arm
« Reply #22 on: November 03, 2009, 11:59:39 AM »
steve-o i thought you have a YJ? that pic is off a TJ with no axle disconnect (one piece pass side axle).
Steve-0
Re: Pitman Arm
« Reply #23 on: November 03, 2009, 12:38:10 PM »
I DO. Mrcabinet has the TJ and the question at hand.
Offline mrcabinet
Re: Pitman Arm
« Reply #24 on: November 03, 2009, 12:46:29 PM »
Yes, it is a 2001 TJ. Whatever is on there is what the p/o had installed at 4 Wheel Parts. The track bar does have a riser bracket. No high steer - all stock parts and mounting locations (except the track bar).
Steve-0
Re: Pitman Arm
« Reply #25 on: November 03, 2009, 01:09:39 PM »
And the damper shock is mounted to that bracket as well. What els is mounted to it? Looks like there is something else in the knuckle end of it...
Offline mrcabinet
Re: Pitman Arm
« Reply #26 on: November 03, 2009, 01:25:06 PM »
I don't know. I'll have to look when I get home this evening. Actually, I just looked at another pic I had and it is the sway bar link.
« Last Edit: November 03, 2009, 01:35:54 PM by mrcabinet »
Steve-0
Re: Pitman Arm
« Reply #27 on: November 03, 2009, 01:55:51 PM »
So that would seem like it would explain the one side of the sway bar being higher then the other.
Offline mrcabinet
Re: Pitman Arm
« Reply #28 on: November 03, 2009, 02:07:44 PM »
The mounting points of the track bar and pitman definitely do not align, so I'm thinking of doing the drop pitman arm. If I have it correct, the rule of thumb would be that if you have the track bar bracket then the dropped pitman should be used. If there's no bracket, then stick with the stock pitman arm, correct?
Re: Pitman Arm
« Reply #29 on: November 03, 2009, 02:14:00 PM »
for some reason when i read your post i thought you were asking if yours should look the same or if you're missing something there, nevermind then.
