Author Topic: Stalling  (Read 1992 times)
jeepyj95
Stalling
« on: October 27, 2009, 02:39:36 PM »
Well i have and auto 4 popper and when i'm in drive it will stall. its only actually stalled once but it acts like it wants to when i come to a complete stop and hold down the brakes. i've been told to check out the CCV, and the O2 sensor. the last time i did sparks and wires, etc was summer 07. i've removed the restrictors and the plate on the air box. any ideas?
Re: Stalling
« Reply #1 on: October 27, 2009, 07:21:44 PM »
what's your idle in Park and in Drive? could be the IAC or the valve cover breather fittings (the one in the valve cover or the one in the intake manifold). I think the autos need a higher idle in park or neutral but i'm not sure what that is, my best guess is 900rpm.
jeepyj95
Re: Stalling
« Reply #2 on: October 27, 2009, 08:31:02 PM »
i usually idle at about 850-900 in park and then when driving....i'll look at it.
Re: Stalling
« Reply #3 on: October 27, 2009, 08:59:43 PM »
that should be good, check the IAC and valve cover and manifold fittings and also make sure the line between the valve cover and intake manifold is not plugged - can't think of anything else obvious unless it's something more complicated like misfire or fuel problem. Do you have any electrical issues that you know of?
jeepyj95
Re: Stalling
« Reply #4 on: October 29, 2009, 01:46:58 PM »
no electrical problems that i know of. its actually been running fine the past few days. but just in case im gonna replace the CCV and possibly the o2 sensor when i get home from school. if that isnt it then thats just one less thing to worry about
Steve-0
Re: Stalling
« Reply #5 on: October 29, 2009, 03:31:29 PM »
Have you checked the CPS? That can cause stalling. Check this out... http://www.naxja.org/forum/showthread.php?t=986261
