Author Topic: Installing aftermarket air intake on 90 YJ  (Read 40596 times)
C.Redbeardd
Re: Installing aftermarket air intake on 90 YJ
« Reply #90 on: November 13, 2009, 01:00:11 AM »
just got my fram air hog in.
robertsiii
« Reply #91 on: November 26, 2009, 08:44:16 PM »
Found a Spectre Performance Cold Air Intake that the rice burners use.  Mounted up just fine to my tbi intake .Used there mounting stand-off kit . This raised my intake roughly 8"  sits right under hood support rod on driver side . Tried to load pic but says file is to large.
« Reply #92 on: November 26, 2009, 09:09:47 PM »
have any pics? ho does it connect to the tbi.. the main thing that makes it more difficult is that you have the wires for the injector that have to make it through if you remove the plastic thing that the stock intake clips onto....
robertsiii
« Reply #93 on: November 27, 2009, 06:44:01 PM »
send me our e-mail address for pics      the intake attaches to the existing snap'on  tbi  cover  with a hose clamp.
« Reply #94 on: November 27, 2009, 08:22:16 PM »
you can go to www.photobucket.com and open an account - then you can share your pics on this forum using the IMG tags (click on share on the pic you uploaded on photobucket, copy the img link and paste it in your post)
robertsiii
« Reply #95 on: November 28, 2009, 07:15:43 AM »
Thanks Sharpxman, below are pics of intake  in next post.  cost about 60 bucks
« Last Edit: November 28, 2009, 07:28:25 AM by robertsiii »
robertsiii
« Reply #96 on: November 28, 2009, 07:24:11 AM »
here you go
« Reply #97 on: November 28, 2009, 10:40:27 AM »
aw that makes sense... your motor is so clean :eek:...  that's going to be sucking some real hot air if your going slow / crawling down a trail. but its hard to get much better without a snorkel..  thanks for the pics.  :thumb:
« Reply #98 on: November 28, 2009, 11:16:11 AM »
Interesting your alternator is way up high ,
Mine is about crankshaft level on the passenger side on my 94.
Is that a AC pump or a air pump below it?
« Reply #99 on: November 28, 2009, 02:30:50 PM »
thats the stock alternator location for the tbi 2.5l with v belts.. idk about the bottom (they didn't offer ac with the 2.5l with tbi iirc).
« Last Edit: November 28, 2009, 02:32:51 PM by chardrc »
Torch_Ind
« Reply #100 on: November 28, 2009, 02:40:51 PM »
can you turn the breather around so it goes over the eng and behind the alt?
if you run water at all I recommend it
robertsiii
« Reply #101 on: November 28, 2009, 06:04:41 PM »
Pics were taken right after i  a tear down to replace intake/exhaust gasket  , Not worried about high temp, running 160 themistat  and no ERG.  My temp on highway @70 is 170  Ive made some  deep water crossings  at  low speeds with no problems.  Should be going to elec. fan soon .  :clap:  That is my a /c compressor (aftermarket)  only run in hottest summer months in sunny fl.
« Last Edit: November 28, 2009, 06:07:58 PM by robertsiii »
« Reply #102 on: November 28, 2009, 06:16:11 PM »
this may be geting abit off topic.. but did you notice any significant difference without the egr?
vprsrul
« Reply #103 on: November 28, 2009, 06:19:15 PM »
This bullitin was in my warranty class,  so if you guys are still under warrenty on anything and you bring your vehicle in for service remember to clean you airbox and replace your filter with the factory one.  also note that they will NOT void your warranty unless they find damage...  this bullitin was in my chrysler jeep subaru vw course this week.  funny thing is that we will clean and reoil your filter for you if you ask.... but if it damages something its on you!  pretty dumb if you ask me but whatever.  Anyhow in one weeks time we have replaced two rear axles on tj's both were lifted one was a six cylinder.
Bulletin No.: 04-07-30-013B
Date: February 01, 2007
INFORMATION
Subject:
Automatic Transmission Shift, Engine Driveability Concerns or Service Engine Soon (SES) Light On as a Result of the Use of an Excessively/Over-Oiled Aftermarket, Reusable Air Filter
Models:
2007 and Prior GM Cars and Light Duty Trucks
2007 and Prior Saturn Models
2003-2007 HUMMER H2
2006-2007 HUMMER H3
2005-2007 Saab 9-7X
Supercede:
This bulletin is being revised to add models and model years. Please discard Corporate Bulletin Number 04-07-30-013A (Section 07 - Transmission/Transaxle).
The use of an excessively/over-oiled aftermarket, reusable air filter may result in:
Service Engine Soon (SES) light on
Transmission shift concerns, slipping and damaged clutch(es) or band(s)
Engine driveability concerns, poor acceleration from a stop, limited engine RPM range
The oil that is used on these air filter elements may be transferred onto the Mass Air Flow (MAF) sensor causing contamination of the sensor. As a result, the Grams per Second (GPS) signal from the MAF may be low and any or all of the concerns listed above may occur.
When servicing a vehicle with any of these concerns, be sure to check for the presence of an aftermarket reusable, excessively/over-oiled air filter. The MAF, GPS reading should be compared to a like vehicle with an OEM air box and filter under the same driving conditions to verify the concern.
The use of an aftermarket reusable air filter DOES NOT void the vehicle's warranty.
If an aftermarket reusable air filter is used, technicians should inspect the MAF sensor element and the air induction hose for contamination of oil prior to making warranty repairs.
Transmission or engine driveability concerns (related to the MAF sensor being contaminated with oil) that are the result of the use of an aftermarket reusable, excessively/over-oiled air filter are not considered to be warrantable repair items.
robertsiii
« Reply #104 on: November 28, 2009, 06:47:40 PM »
temp. dropped 20 degrees ,quicker exceleration at low end , more speed at top end .
