Author Topic: Internet Deals Thread  (Read 70220 times)
C.Redbeardd
Re: Internet Deals Thread
« Reply #30 on: November 11, 2009, 03:13:44 PM »
well this is a forum for 4 cylinder jeep engines. I'd say, yes. lol
« Reply #31 on: November 11, 2009, 04:21:08 PM »
« Reply #32 on: November 11, 2009, 04:53:46 PM »
10% off Veteran's Day Sale at 4wd.com
Promo code VET09
thought i'll share, just got an email.
EDIT: apparently you have to call to get the discount 1-800-914-0065 valid Wed Nov 11 and Thu Nov 12, 2009.
tires seem to be on sale already when you buy 4 you get $100 off, not sure if this code apply to that already discounted deal, if it does it's the best price on tires i've seen - 4 x BFGoodrich Mud-Terrain T/A KM2 Tire, 35x12.50R15 show in cart at $707, if this veteran's day promo apply then would be $637 = $159/tire - quite a deal for those (again not sure if you can redeem that code but if you can it's worth the call)
« Last Edit: November 11, 2009, 05:06:55 PM by sharpxmen »
Offline zowtiak
« Reply #33 on: November 11, 2009, 09:40:00 PM »
I couldnt agree more. I did go to the purolater site before putting in my newbie question and checked to see if the 30001 would work. I diligently spent about 20 minutes doing a "next" button marathon and when I got to jeep it did not show it as compatible. But i am glad i am wrong because i am going to get a pair of the filters to go with my air hog and sure drain.
C.Redbeardd
« Reply #34 on: November 11, 2009, 09:45:13 PM »
I ordered an air hog. I should be recieving it tomorrow.
« Reply #35 on: November 11, 2009, 10:16:13 PM »
It won't shot it as matching because it's not the stock size.  These are over-sized so they are not recommended by the mfg.  Many of us have been running the PH8A style filter for years.  It's slightly larger then the stock PH16.  I would recommend going with a PH997A (I think that's the one in the faq).  That is more then twice the size of the PH16.  Amazon does not have a sale on them though.  They aren't as common as the PH8A.  Seems most everything uses a PH8A.
« Reply #36 on: November 11, 2009, 11:24:06 PM »
When you install the larger filter check the clearance between it and the motor mount. On my 94 the original mounts were like 1/8 inch from the filter, I noticed a dent in the filter from impact from wheeling. Once I replaced the mount (Another failure) it was different and had plenty of room.
C.Redbeardd
« Reply #37 on: November 16, 2009, 02:03:23 PM »
Question: Where can i find the fram air hog cleaner and oil kit?
« Reply #38 on: November 16, 2009, 03:26:32 PM »
Offline zowtiak
« Reply #39 on: November 16, 2009, 11:50:38 PM »
I pulled the trigger on the airhog and it should be here soon. do i need to oil it first?
vprsrul
« Reply #40 on: November 17, 2009, 09:15:30 AM »
should be oiled from the manufacturer.  if not you will be able to tell.
Offline zowtiak
« Reply #41 on: November 17, 2009, 07:12:35 PM »
Thanks. I read earlier that it should be orange too.
« Reply #42 on: November 20, 2009, 11:55:44 PM »
the oil form the manufacturer is just to preserve it,
they should have a booster oil done before install.
At least thats how K&N and Uni-filter are installed.
« Reply #43 on: November 21, 2009, 01:44:20 PM »
Hmm, the Fram is Drop-In and go.  I don't think K&N's require additional maintenance out of the box or else a large majority of people aren't installing them properly.
« Reply #44 on: November 21, 2009, 06:57:00 PM »
thought so too, my Apollo's instructions only mention to service it after whatever miles but does not say to add any oil for the first install.
