Author Topic: EGR Tube Cracked  (Read 1677 times)
robertsiii
EGR Tube Cracked
« on: November 15, 2009, 05:18:35 PM »
As stated i have an in line crack in my egr tube running to my header . Are these tubes still available? I saw were some machine shops are making block-off plates so you can remove the egr valve and cap it and cap  the header port .Has anyone on here done this? 1990 2.5L TBI  thanks for the info.
« Last Edit: November 15, 2009, 05:32:26 PM by robertsiii »
Re: egr tube cracked
« Reply #1 on: November 15, 2009, 05:37:19 PM »
i haven't heard of anyone disconnecting the egr on the 2.5l (not that ive looked) but my understanding was that it was fairly common with the Chevy guys with tbi.. i don't know the effects (other than more power because your not running on exhaust)... to simulate blocking off the egr tube you can disconnect the vacuum line from the egr (make sure to plug the line you take off or it will be a vacuum leak when the egr is being told to turn on). so id give that a try first as its super easy to do and should show you the side-effects. wouldn't it be fairly easy to put a small bead of weld over the crack if you wanted to keep the egr intact.
robertsiii
Re: EGR Tube Cracked
« Reply #2 on: November 15, 2009, 07:36:31 PM »
Thanks for the reply .  i"ll give that test a try.  might weld er up if it doesn"t act right.
