Author Topic: All outside lights come on when hitting the brakes!!!!  (Read 2008 times)
99t/aman
« on: November 16, 2009, 08:02:32 PM »
Well i have put 2 tuen signal switchs in my jeep for this issue, first one lasted 2 weeks, next one lasted like 3-4 months.  Now it is doing it again and i am wondering what keeps causing this issue. Anyone have any ideas??? Thanks
Re: All outside lights come on when hitting the brakes!!!!
« Reply #1 on: November 16, 2009, 08:06:25 PM »
check if you have good ground at the stop lights and headlights - that's the only thing i can think of unless there's some weird wiring issue (some short somewhere). If you did some work on the wiring retrace your steps, you might find the problem there.
« Reply #2 on: November 19, 2009, 01:55:27 AM »
I've seen this when the turn signal element burns out and the
remaining chunk falls across the tail light element in the bulb.
Drove me crazy for a couple hours till I tracked it down.
Jlayne
« Reply #3 on: November 30, 2009, 09:15:09 PM »
Check you trailer plug... easy to drag and smash a wire.  It can cause all kinds of nasties.
