Author Topic: Rear Bumpers  (Read 4961 times)
Offline Mozman68
  • Poseur Extraordinaire®
Re: Rear Bumpers
« Reply #15 on: December 16, 2009, 04:26:48 PM »
JCR....$650...recessed hitch....
Re: Rear Bumpers
« Reply #16 on: December 16, 2009, 06:09:28 PM »
The JCR is very similar to the BulletproofMFG/Body Armor carrier.  The main difference being the hoop is taller so the can is tucked in a few more inches.  Still kind of pricey at $700 shipped.
I also like the Gavin Wilderness but that's a lot of crap on the rear.
Re: Rear Bumpers
« Reply #17 on: December 16, 2009, 09:26:24 PM »
The one thing I don't like about that design is the carrier is in front of the bumper so it essentially becomes the bumper.  I'm sure it's a stronger way of mounting the carrier but I like the ones that are ontop of the bumper, leaving the bumper to do it's thing.
I also like the bumpers that reinforce the rear cross-member and have frame tie-ins.  I've been rear ended in the Jeep and because the bumper hung off the rear cross-member it was pulled down which torqued the rear cross-member down as well.  That all had to be replaced.
If you do one on top of the bumper with a spindle type swingout, make sure you put it in double shear. Like the Warn one.
http://www.mountainoffroad.com/Catalog/FramePlates/crossmember-frame-plates.htm
Here is a crossmember plate to add some beef.
http://www.boulderbars.com/tireracksystem.htm  This is where I got the idea to do my tire carrier. I like this type of set up. I have had great luck with it. (I can't believe he jeweled the beadlock on that spare tire) All J makes nice stuff but it's a bit pricey IMO.
Re: Rear Bumpers
« Reply #18 on: December 16, 2009, 10:53:17 PM »
I do like that rack but it's pricey as well.
I'm liking this setup.
http://www.jeepforum.com/forum/f43/treks-tire-carrier-tj-lj-cj-models-805452/
Jesse-James
Re: Rear Bumpers
« Reply #19 on: December 16, 2009, 11:17:54 PM »
That is a sweet setup!
Offline aw12345
    • my jeep picture page
Re: Rear Bumpers
« Reply #20 on: December 17, 2009, 05:07:04 AM »
Is a nice setup if you use rear corner armor and backup plates on the inside.
Savvy now sells rear aluminum 6160 T6 corner blanks for YJ's for 299 is a hell of a deal. The material alone is over 200 bucks
2006 Jeep Wrangler TJ SE
2004 Jeep Wrangler TJ SE
Re: Rear Bumpers
« Reply #21 on: December 17, 2009, 08:41:32 AM »
That is pretty nice.  A good feature would be for the gas can shelf to be removable.
Re: Rear Bumpers
« Reply #22 on: December 17, 2009, 11:50:45 AM »
Their kit uses backing plates as reinforcements.  They say without corners you can run up to 37's.
And the gas can mount is removeable as it's optional.  The tire also has several mounting locations as the plate has several different holes drilled.
I checked Savvy and they want $312 for blanks.  Not sure if I want to be cutting the wheelwell openings with a saw.  I'd like to find some corners that have everything but the lights cut out.  Then I would be able to locate the lights whereever I wanted or even move them to the bumper.
« Last Edit: December 17, 2009, 12:10:29 PM by Jeffy »
Re: Rear Bumpers
« Reply #23 on: December 17, 2009, 01:21:57 PM »
It's kind of strange that Treks doesn't list that carrier for the YJ. You would think it would install about the same as on a CJ.
Re: Rear Bumpers
« Reply #24 on: December 17, 2009, 02:35:55 PM »
My guess is this;  The CJ does not have side hinges.  If you look at the TJ above the rack seems to be using the side hinges as bolting points.  I'm sure the upper hinge is also tied into the rollbar which the CJ does not have in the same location.
Re: Rear Bumpers
« Reply #25 on: December 17, 2009, 02:50:13 PM »
Yeah, it must be those small differences that together make a big difference.
Offline Mozman68
Re: Rear Bumpers
« Reply #26 on: December 17, 2009, 06:42:31 PM »
look at how clean the inside of that wheel well is...christ...
Re: Rear Bumpers
« Reply #27 on: December 17, 2009, 07:35:19 PM »
Well, yes they washed it.
