Author Topic: are my tires too big?  (Read 5518 times)
rc10t4orange
Re: are my tires too big?
« Reply #15 on: February 05, 2010, 10:40:39 AM »
Anyone got an auto TJ with 31's and 4.10's? How's it go down the road? Got 31's coming for mine this weekend.
Banshee600
« Reply #16 on: February 05, 2010, 12:37:03 PM »
I run 32x11.50 bfgs mudders  and 4.10 gears 3.5 " lift on the hyway 65mph no problem in 5th gear get a tb and spacer from bounty hunter helped alot
« Reply #17 on: February 05, 2010, 01:49:01 PM »
I ran 31's w/3.73's and it was pretty good. With 4.10's you should be happy.
« Reply #18 on: February 05, 2010, 04:24:20 PM »
With an auto trans you will be just fine
  • Poseur ExtraordinaireŽ
« Reply #19 on: February 06, 2010, 04:21:26 AM »
I threw 31's on the day I brought my Jeep home...4.10's, manual....was non problem at all....
Offline bootguy
« Reply #20 on: February 07, 2010, 08:07:38 PM »
I played around with my sons 94YJ and found out that changing the speedo gear really helps the engine run better, because it is getting correct info.  If that will help on a manual transmission, i dont know but it is a must on the auto.
« Reply #21 on: February 07, 2010, 08:43:31 PM »
Yes, it helps both.
