Author Topic: work on 2.5 liter with TBI/rex  (Read 1715 times)
cz777
« on: February 02, 2010, 04:27:19 PM »
well i am putting a  mag-pick up distributor in [ rex ignition is running now] with msd 6al with a little of wiring work -starts Wednesday  anybody do this mod yet ? post after work done soon !
cz777
Re: work on 2.5 liter with TBI/rex
« Reply #1 on: February 03, 2010, 10:39:29 PM »
well its working the mod ! get a distributor with vacuum advance  wire into the system as TBI is now freestanding . disconnect old French  system but use as backup system --yellow wire on the 3 wire connector is used for key ignition the msd box and rest wire like ford ignition set up .....ok timing was a pain because ref marks dont line well so i set at app. 6 marks from base of mag timing hole ....next run the jeep up a hill as fast and engine warm to hear any pinging -it sounds better and no flat spots in power ! also i am going to get a 1983 duel vacuum advance for a f-150 300 cid use the retard side for the vacuum  to the manifold side - yes this will work for the rest so please look in this mod ...please look at how volvo's 940 are wiring up with the rex/reginea sytem ....thxs for other good ideas to do ....
« Reply #2 on: February 03, 2010, 11:42:04 PM »
cool, you should take some pics and post them. any improvement in performance once you got it dialed in?
« Reply #3 on: February 07, 2010, 04:08:09 PM »
:) Its funny, the distributor on the MPI 2.5 only fires the Injection, I know a guy who tried to wire a MSD to the distributor instead of the coil and blew the computer up! Funny because its well documented if you look that the coil wires are what needed wiring up..
« Reply #4 on: February 07, 2010, 05:33:58 PM »
tbi distributor has no electronics in it as far as sensor stuff goes...
sounds like a nice mod, some pictures and updated results would be nice.  :thumb:
cz777
« Reply #5 on: February 06, 2011, 04:42:04 PM »
well i have great success with the MSD mod to the ignition system ! i left the rexis system in place [back up system if things go wrong ]but unpluged from the system [its out time by app. 90* with rexis ].. the main power rexis plug is used for ignition switch ''hot '' for msd box  --rebuilt distributor is from a 1983 amc thxs to auto zone  with the ford connectors from ford ..gas mileage is at 19 /20 now smoother ideal ......
