Author Topic: 1/2 quart oil gone but little on ground  (Read 7274 times)
Re: 1/2 quart oil gone but little on ground
« Reply #15 on: February 16, 2010, 11:57:51 AM »
It is all over the valve cover and underbody.  It is being forced out of every where it can it seems.  The blowby is really hard.  Yea I drove it everyday since first posting.  The oil only gets pushed out when I make the drive from Carson City to Reno at highway speeds.  While doing normal town driving it doesn't do it.
*Edit* I did add a can of seafoam to try to loosen up the pistons (incase they were gunked) and it seems there is more leakage now.
take the compression. If you're thinking of a quick fix i would suggest not to drive it anymore until you know what it is - if you have a broken piston ring it will scratch the cylinder and you'll have to bore it out - if it's not scratched you could go on the cheap side replacing 1 piston and all the rings, won't be perfect but you can get by for a little bit until you find a deal on a good motor.
« Reply #16 on: February 16, 2010, 12:31:19 PM »
If there is blowby then adding SeaFoam would be the worst thing you can do.  That 'gunk' was helping you make compression.
Do a compression test and see how bad the rings are.
bammerman
« Reply #17 on: February 19, 2010, 03:17:09 PM »
Found where the leak is.  Front seal by harmonic balancer, that cover there.  It is pouring out of a bolt.
« Reply #18 on: February 19, 2010, 03:57:36 PM »
didn't your mechanic just do some work there? did he forget to put that screw in?
bammerman
« Reply #19 on: February 19, 2010, 08:45:28 PM »
Ya we changed harmonic balancer. the bolt there just coming out from behind it
« Reply #20 on: February 19, 2010, 10:52:42 PM »
is the cover cracked? that wouldn't be due to a pry bar action by any chance?
