Author Topic: YJ Add a leaf  (Read 3584 times)
AGUHR
YJ Add a leaf
« on: February 10, 2010, 05:46:50 PM »
I have a 2" Shack lift, can I also add a 1.25" add a leaf to add more lift? Or would there be other adjustments I would need to do?
Re: YJ Add a leaf
« Reply #1 on: February 10, 2010, 06:31:08 PM »
you can add a leaf lift but that is a lot of shackle - do you have a 2'' shackle lift (that means 4'' over stock shackle) or a 1'' shackle lift (2'' over stock)? if it's the latter you're fine, if it's the 4'' over stock then i suggest rather getting a higher lift and reduce the shackle size (you're doing the work anyway). Also keep in mind that add a leaf will result in quite a stiff suspension (all the YJ lift kits are but this one in particular to compensate for the other leafs in the pack).
Re: YJ Add a leaf
« Reply #2 on: February 10, 2010, 07:25:13 PM »
I used to run an AAL and the ride was horrid. I'd strongly recommend finding something else.
Re: YJ Add a leaf
« Reply #3 on: February 10, 2010, 08:27:11 PM »
The short AAL's ride horrible but many of the long ones aren't too bad.  I make my own using a pair of used front springs from a YJ, gives 1.5" of lift and doesn't stiffen the ride.
With that much combined lift you will likely need longer shocks, a transfer case drop, and may need to adjust the brake lines.
Re: YJ Add a leaf
« Reply #4 on: February 10, 2010, 09:38:05 PM »
AAL.... :nono:
TJ flares... :nod:. Cutting the sheet metal and adding the TJ flares will gain you about the same as the AAL without affecting the ride.
« Last Edit: February 10, 2010, 09:39:19 PM by FourbangerYJ »
AGUHR
Re: YJ Add a leaf
« Reply #5 on: February 11, 2010, 06:12:09 AM »
TJ Flares are what I will probably do, I didn't know what adverse effects or canges I would need - but all your thoughts make sense.
I've been looking for a used set locally and haven't been able to fine one yet.
thanks.
Re: YJ Add a leaf
« Reply #6 on: February 11, 2010, 08:59:51 AM »
I ran TJ flares and AAL's for years, great combo for 32" tires without heavy modifications.  The 1.5" AAL made from a a pair of stock front springs does not stiffen your ride.
