Author Topic: need a picture from a 95 4 cyl. YJ  (Read 3325 times)
jeepin1995
« on: February 19, 2010, 11:04:44 PM »
i need a picture of the plug that goes into the distributor/coil..... thanks in advance!
Pete
Re: need a picture from a 95 4 cyl. YJ
« Reply #1 on: February 20, 2010, 03:14:49 PM »
FYI there are several options becasue 84/95 was really a 94 box of parts assembled in 95 with whatever jeep felt like using. My 94 has a 96 distributor for instance.
Good luck!
jeepin1995
« Reply #2 on: February 20, 2010, 06:37:27 PM »
hmmmm heres my deal..... i swapped a chevy 350 in my 95 YJ and cut my wiring all to hell..... now i bought a harness from a guy that was parting his 95 and need to know which plug is the dist/coil plug..... i have a LOT of extra plugs because most everything is gone..... anybody wanna snap a pic?
« Reply #3 on: February 20, 2010, 07:11:05 PM »
FSM from the faq section will help you with that. if i have time later on i can post a pic or a snap from the FSM (if you're in a hurry download it, i think the connectors are in the 8W section but not 100% on it (the filename contains that 8W suffix)
jeepin1995
« Reply #4 on: February 20, 2010, 07:30:56 PM »
found the thread..... links didn't work.....
« Reply #5 on: February 20, 2010, 08:34:34 PM »
the ignition coil connector has 2 wires, both are 18 gauge - one is Dark Green with an Orange stripe (is the one that comes from the ASD), the other wire is Grey with no stripe and comes from the PCM. the only other connector that has 2 wires on that side of the harness is the alternator field control (driver) that has the same dark green with an orange stripe but the second wire is dark green with no stripe. so you're looking for a 2 wire connector with one of them grey for the ignition coil.
this should suffice to identify the coil connector, hope this helps.
« Reply #6 on: February 21, 2010, 12:38:31 AM »
The distributor on the YJ only triggered the fuel injection. The spark was off the crank sensor.
Just wanted to make sure you knew its weird wiring there...
Have you considered the painless YJ WIring kit?
jeepin1995
« Reply #7 on: February 21, 2010, 12:51:12 AM »
good info..... so is there a way to wire the 350 distributor from the jeep harness?
« Reply #8 on: February 21, 2010, 12:59:29 AM »
The electrics in the YJ used the ECU to fire the coil, so I'd guess NO. unless you carefully dissect the harness plug for the ECU and adapt it to the V8 computer.. Assuming it has one.. The Painless wiring kit is by far the easiest way to wire a Chevy into a jeep ..
jeepin1995
« Reply #9 on: February 21, 2010, 05:03:37 AM »
well....the 350 is carbed, only wire i lack is for the distributor, everything else works-starter, alternator, etc...
« Reply #10 on: February 21, 2010, 08:50:03 AM »
is it a points type or electronic? the cam sensor in the YJ dist is powered at 5v or 8v, can't remember exactly - so you'll need a switched 12v for yours - ASD won't work since it is controlled by the PCM, so some mods on the PDU are needed to use that.
jeepin1995
« Reply #11 on: February 21, 2010, 01:58:08 PM »
pretty sure its points..... i guess i need to figure out another route....
« Reply #12 on: February 21, 2010, 03:16:54 PM »
Is this a trail only rig? if thats the case I'd go way different. Just use a generic harness and scrap the YJ wiring.
No Points V8 is legal in any YJ for street use, I know not everybody has smog checking,
but it can really bite you on the rear. I know folks who had thier vehicles impounded in UT
and CA for various DOT violations.
Can you give us a high level description of what you have and where you need to get to?
« Reply #13 on: February 21, 2010, 05:10:22 PM »
if it's points you only need 1 switched 12v to the coil and another wire from the coil going to the distributor points connector
jeepin1995
« Reply #14 on: February 21, 2010, 06:47:45 PM »
heres what i got..... the dist. has just one wire running to it.... it runs thru a switch in the cab.... thats how i turn it on and off (i know..... kinda ghetto) coil and everything built into the dist.  everything else is hooked up pretty good..... the dist. is all i have left....
