Author Topic: Hood scoop  (Read 4030 times)
Hood scoop
« on: March 27, 2010, 09:56:00 PM »
So do you think there is any added performance gained from a hood scoop? Something kinda like this.
« Last Edit: March 27, 2010, 09:58:45 PM by FourbangerYJ »
95yjman
Re: Hood scoop
« Reply #1 on: March 27, 2010, 10:23:40 PM »
Water fording maybe?  I don't know though
Re: Hood scoop
« Reply #2 on: March 27, 2010, 10:51:33 PM »
if you have a cone filter and a shield around it so the intake takes it's air thru the scoop you will make some HP - as an example 20F intake air temp difference results in 5 HP loss or gain depends how you look at it.
Re: Hood scoop
« Reply #3 on: March 27, 2010, 11:04:58 PM »
Well the reason for that scoop is because it's diesel and has a snorkel that attaches to it.  There will probably be a few HP gain since diesels tend to run hot and those Jeeps are deployed in Egypt and other hot climate areas but that's not really what it's for.
Re: Hood scoop
« Reply #4 on: March 28, 2010, 09:54:02 AM »
It would seem that it would allow more air in to the air box. I put on the stock TJ air tube. The inlet is about the same spot as the JK. Not sure it would be worth building a scoop. As Sharp mentioned a box inside the hood would also need to be built.
Re: Hood scoop
« Reply #5 on: March 28, 2010, 12:04:27 PM »
Building a shield/box would help seal off the engine compartment from the scoop and you get better flow with the positive pressure.  Otherwise, the scoop is just going to be a vent.
If you really wanted to keep all of the air cool then I would probably go back to using the YJ routing which is shorter and you're going over the engine.  Then using heat shielding over everything.
Re: Hood scoop
« Reply #6 on: March 28, 2010, 02:56:50 PM »
With the motor moved forward 4 inches the stock YJ air box set up was replaced with a Rock-it city tube. Then after messing around with the K&N I swtiched to the TJ setup. I couldn't figure out how to get the stock YJ airbox to work without a lot of work.
I don't mind the TJ setup. I still have the trumpet on. Not sure I am going to mess around with it.
Re: Hood scoop
« Reply #7 on: March 28, 2010, 04:31:09 PM »
You could use a new elbow that's 4" shorter on a YJ box?
The other problem I see is if you ford any deep water, that's going to get sucked right in as the water pushes over the hood.
« Last Edit: March 28, 2010, 04:34:04 PM by Jeffy »
Re: Hood scoop
« Reply #8 on: March 28, 2010, 05:12:36 PM »
 :confused: could be. I don't think I have the stock box anymore.
Good point on the water crossing. Not that I have that around here but you never know. I would like to do Fordyce some day.
YJmechanic
Re: Hood scoop
« Reply #9 on: March 29, 2010, 11:34:23 PM »
is everyone forgetting the most important part?  IT LOOKS AMAZING!   :roflol:
