Author Topic: Fuel pressure check question  (Read 2259 times)
Re: Fuel pressure check question
« Reply #15 on: April 11, 2010, 01:56:57 PM »
red
i dunno then, mine was blue and so were a few others that i pulled out.
what was the pressure you got (see my other reply i edited after you posted)
Complete Loser
« Reply #16 on: April 11, 2010, 02:00:51 PM »
When i installed the gauge with valve in place, i got zero.
Removed the valve, and installed gauge. Primed pump and got 38ish (couldnt see well when turning key on). And with key (pump) on after it primed, it would leak back down to zero in about 12seconds.
Started it up, and was running at about 37ish psi. I figure to compensate for the long rubber hose of the pressure tester, and the gauge itself, thats about right.  ?
