Author Topic: Fuel pressure check question  (Read 3061 times)
Complete Loser
« on: April 10, 2010, 04:13:47 PM »
Ok. Im obviously doing something wrong. Because i have a new pump, the jeep is running, yet my gauge says 0. I have checked the gauge, its ok.
Re: Fuel pressure check question
« Reply #1 on: April 10, 2010, 04:45:04 PM »
first off you should not tighten that just by hand with your fingers, most likely the valve in there is not getting pressed so there's no pressure past it - is there any gas coming out when you take the hose off?
Complete Loser
« Reply #2 on: April 10, 2010, 05:30:03 PM »
ya. some gas spills when i take the hose off. Not much. But some.
Complete Loser
« Reply #3 on: April 10, 2010, 05:33:02 PM »
while its running, i press the valve pin down all the way, and gas dribbles out. I figure much more should come out than just a dribble. ?
« Reply #4 on: April 10, 2010, 05:43:17 PM »
Is that a tire pressure gauge?
Complete Loser
« Reply #5 on: April 10, 2010, 05:44:51 PM »
Its a fuel system pressure checker.
« Reply #6 on: April 10, 2010, 05:46:28 PM »
If you think you're getting pressure then you can always remove the schrader valve and try it.
Complete Loser
« Reply #7 on: April 10, 2010, 05:48:50 PM »
The schrader valve comes off?  If thats the case, i will try that.
« Reply #8 on: April 10, 2010, 05:58:37 PM »
x2
just like the tire one, but is not the same - the rubber is fuel resistant, so don't lose it.
Complete Loser
« Reply #9 on: April 10, 2010, 06:00:07 PM »
Oh. you mean the valve comes out.
ok.
Complete Loser
« Reply #10 on: April 11, 2010, 12:52:38 PM »
Took the valve out. Checked pressure. Problem solved. Thanks. :)
« Reply #11 on: April 11, 2010, 12:54:45 PM »
NP!  I'm betting the gauge wasn't pressing the valve all the way down.
Complete Loser
« Reply #12 on: April 11, 2010, 12:56:28 PM »
Thats what i figured, except when i would use a nail to press the valve all the way down, i would still only get a tiny dribble of gas. Kinda makes me think the valve is fubar'd.
n e ways, its checked and good. :) Thanks again.
« Reply #13 on: April 11, 2010, 01:54:33 PM »
what's the color of the rubber on the valve? should be blue, if it's black might be that somebody replaced it with a tire valve and the rubber swelled so is not releasing anymore.
EDIT: what pressure did you have, and did you remove the vac port when you measured it?
« Last Edit: April 11, 2010, 01:55:32 PM by sharpxmen »
Complete Loser
« Reply #14 on: April 11, 2010, 01:55:41 PM »
red
didnt see any blue or black.
« Last Edit: April 11, 2010, 01:55:59 PM by Complete Loser »
