Author Topic: Electric Radiator Fan Swap - 94 Grand Am  (Read 6661 times)
Re: Electric Radiator Fan Swap - 94 Grand Am
« Reply #15 on: May 08, 2010, 11:50:49 AM »
Specifies the 4.0L XJ only.  The 2.5L XJ does not have the aux fan.
« Reply #16 on: May 08, 2010, 12:00:33 PM »
the feature might still be there as there's no harm in it but it's a long shot - the PCMs are same design just the 2 missing cylinder drivers for the 2.5L
would be great if it turns out to be available on the 2.5L
can probably be tested with an additional PCM temp sensor and engine running and stick the temp sensor in boiling water - if pin 31 gives ground and when taken out of the boiling water there's no ground then it works (fingers crossed).
« Last Edit: May 08, 2010, 12:01:08 PM by sharpxmen »
« Reply #17 on: May 08, 2010, 12:05:27 PM »
Fingers are crossed ;)
It would be like the 15 gallon tanks in the 2.5L that you just have to cut insert in the hole to make 20 gallon.
« Last Edit: May 08, 2010, 12:07:15 PM by 1995yj »
« Reply #18 on: May 08, 2010, 12:07:23 PM »
good find  :thumbsup: keep us posted with this, i'm really interested. thanks in advance
« Reply #19 on: May 08, 2010, 12:58:34 PM »
I just looked for the Dark Blue / Pink wire (DB/PK) in my harness and it's not there.  Next weekend, I'll pull the connector, add a lead to #31, re-attach, and test.
I looked up the relay and connector for the XJ.  The fan control relay on the XJ is the horn relay on the YJ.
One good thing has come of all this so far.  I found two loose connectors on my harness by the map sensor.  I found out one is for a hood light (didn't know it was an option) and the other was a TCC relay which I guess is for locking the torque converter on a A/T, but I'm going to tap my fan relay on it's white/yellow switched iginition  :pirate:  Saves a few extra feet of wire.
