Author Topic: Under dash wiring changes?  (Read 7980 times)
Re: Under dash wiring changes?
« Reply #15 on: April 21, 2010, 04:39:34 PM »
OK when looking at Schematics wires are listed as Gauge and Color.  So that yellow wire on the blue plug is a 14 gauge Yellow wire.  On your '92 it's 14GN or 14 gauge Green.
From the schematics it looks like that 14GN turns into a 16GN which goes to a relay.  The relay is what connects the starter to the power distribution center.  12RD should head to the PDC while a 14GN/WT (14 gauge green with white stripe.) goes to the starter.
Here are the schematics:
czjeeper
« Reply #16 on: April 21, 2010, 06:01:20 PM »
Thanks for all the help.
I'm kinda lost on what to do though.
I don't know what to do to make it work.
« Reply #17 on: April 21, 2010, 06:08:10 PM »
Well, make sure everything is wired properly (pin-outs match etc...) then make sure there is connectivity with a VOM.  Double check that starter relay as well.  You can always reuse your old harness for that part and see if it starts.  If it does then you know it's something with the new harness.
Handsomefloyd
« Reply #18 on: November 05, 2012, 05:38:11 PM »
I am having the exact same problem. Was there ever resolution to this?
czjeeper
« Reply #19 on: November 05, 2012, 07:25:27 PM »
Wow, that was some time ago.
I ended up repairing my original harness.
The '94 and newer routes the wires a bit differently if I remember correctly.
« Reply #20 on: November 05, 2012, 08:16:05 PM »
yeah, 91 thru 95 had 2 different harnesses but functionally they're the same with very minor differences.
