Author Topic: Inertia Ring vs Hand Throttle  (Read 10466 times)
Re: Inertia Ring vs Hand Throttle
« Reply #15 on: April 23, 2010, 05:54:55 PM »
Felipe the ultimate is a 3 or 4 speed transfercase, will give you good crawlratio and wheel speed when you want it. For  dirt roads and mud a 2.73 or 2.5 low range is pretty much the ticket, but it's to high for crawling unless you have an automatic with a nice first gear ratio. Also the heaviest flywheel/ inertia ring you could possibly put on there would be a great help since it would help keep the engine revved up longer, definitely would help from bogging down and getting stuck in a mud pit
« Last Edit: April 23, 2010, 05:58:14 PM by aw12345 »
« Reply #16 on: April 23, 2010, 06:27:09 PM »
Well, I currently run a 9 Lb inertia ring (TCG set) and the stock TC.  For me, the stock TC has been enough so far.  In the type of terrain we wheel, rocks are not that common; ussually just around rivers, so keeping a higher idle (via hand throttle) is enough.  Of course, ideally, a 3 speed TC would be great, but is it worth the investment vs a $25 dollar Hand Throttle?  For others, it may be worth it, but not to me.
« Reply #17 on: April 23, 2010, 06:29:22 PM »
Actually Felipe for you big heavy tires and rims would help a lot too, anything with a lot of rotating mass once up to speed is hard to slow down also for mud the less stuff you drag through it the better
« Reply #18 on: April 23, 2010, 06:44:00 PM »
I'd probably look into a 3-speed transfer case since you'll never really need 100:1 as it seems it's all slick clay out there and you need more wheel speed.  You already have a SYE so it's a bit of a toss up.  I'd probably consider an axle swap then go 5.13's or 5.38's and stick with the stock transfer case.
Castr8r
« Reply #19 on: April 23, 2010, 07:04:00 PM »
I have a grand total of $7.00 in my hand throttle, including some used parts, all sourced at the local bike shop.  I can't do without it, so I guess I'm not as talented a wheeler as some of you claim to be.  It was used frequently on my trip to Moab because it eliminated the need to grow a third foot.  I use it wheelin' locally when I  end up starting up on a slope and when I'm winching.  I would like to have an inertia ring; it just makes sense to me.  Maybe in the future.
« Reply #20 on: April 23, 2010, 07:14:40 PM »
You all know you can start the jeep with it in gear, 4lo, without your foot on the clutch, right?
subsonic
« Reply #21 on: April 24, 2010, 07:19:46 AM »
Thanks for all of the great answers!
subsonic
« Reply #22 on: April 24, 2010, 08:31:41 AM »
Does the inertia ring effect highway driving?  What about the cost to install or any detrimental effects of adding weight to the flywheel?  Any vibes etc...
« Reply #23 on: April 24, 2010, 09:23:44 AM »
constant hwy driving no, city driving with stop lights and often braking/acceleration yes. less mpg, revs up a bit slower.
« Reply #24 on: April 24, 2010, 11:03:06 AM »
I saw the hand throttle in the quadratec catalog and was on the fence about getting one until I saw all of your posts.  Great information.  :clap:
Is there any inertia rings that are prefered or previously used?  I've read write ups, but from what I can remember it was home brewed from a different application.
Thanks!
« Reply #25 on: April 24, 2010, 12:20:39 PM »
Tricounty gear in Pomona CA sells them, or make your own
« Reply #26 on: April 24, 2010, 12:36:47 PM »
Sweet, I'll give them a call.  :thumbsup:
« Reply #27 on: April 24, 2010, 03:16:24 PM »
Yup.  Hate to admit I have found myself needing to do this before...  And it got me out of a bind (I killed the engine on a steep hil with a lot of dust and small stones; was the only way I managed to get out of it).
X2
That's the one I run.
