Author Topic: Tuffy Box and hung the Hi-Lift  (Read 6343 times)
Re: Tuffy Box and hung the Hi-Lift
« Reply #15 on: May 03, 2010, 10:41:06 PM »
I plan on one day get a set of black steelies, like the Cragar or American Racing 15x10 (or something like them).
15x10's for your 31x10.5's?  I wouldn't recommend it.  I like the no-nonsense look of the stock 15x6's.  These are the only wheels that have that utilitarian look that come standard on the Jeep.  AR767's are nice and come in 4" BS.  Personally I'd go with 4.5" like AEV wheels if you want 12.5's to stay under the flares.
« Reply #16 on: May 03, 2010, 10:44:20 PM »
It won't be until I get bigger axles, tires, spring over conversion, sye, sb350, ... part of my pipe dream.   :whistle:
« Last Edit: May 03, 2010, 10:44:42 PM by 1995yj »
« Reply #17 on: May 03, 2010, 11:43:00 PM »
what Jeffy is saying is that a 10'' wide rim is too much for a 10.5'' wide tire. You should only use 12.5'' and up wide tire with a 10'' rim
« Reply #18 on: May 04, 2010, 07:30:19 AM »
Thanks, but I get it.  I was saying, once if I ever build up, I want some of those rims.  I'll also want some 37-39 inch tires too.  I wouldn't buy rims to keep the same size tire.
  • 4BangerJP.comŪ Donator
« Reply #19 on: May 11, 2010, 08:10:53 PM »
It may be useful for someone else.  I wouldn't mind seeing them just for comparision if you don't mind.  ;)
OK, but I may end up having to use a Flip cam or something else.  Hopefully I can set the thing to yield still photos.  Otherwise I'll end up with these "great" videos of a Hi-Lift Jack already-mounted.
« Reply #20 on: June 22, 2010, 11:15:23 PM »
Took these photos about 6 weeks ago with my phone and finally found cable I was looking for to upload them.
« Reply #21 on: June 23, 2010, 12:58:44 AM »
 :thumbsup:
