Author Topic: Exhaust - Banks Monster Exhaust  (Read 4977 times)
Re: Exhaust - Banks Monster Exhaust
« Reply #15 on: May 25, 2010, 09:54:34 PM »
http://en.wikipedia.org/wiki/CARB
The California Air Resources Board, also known as CARB or ARB, is the "clean air agency" in the government of California. Established in 1967 in the Mulford-Carrell Act, combining the Bureau of Air Sanitation and the Motor Vehicle Pollution Control Board, the ARB is a department within the cabinet-level California Environmental Protection Agency. California is the only state that is permitted to have such a regulatory agency, since it is the only state that had one before the passage of the federal Clean Air Act. Other states are permitted to follow the ARB standards, or use the federal ones, but not set their own.
CARB approved is to California's standards, cuz' wez no bet'r  :pirate:
« Reply #16 on: May 25, 2010, 10:13:30 PM »
i'm in Canada (Vancouver, BC) - still, is it an emissions thing where you need to pass or they'll check every item on your vehicle to see if it's CARB approved?
« Reply #17 on: May 25, 2010, 10:21:33 PM »
I doubt any smog tech would actually spy and check to make sure the cat is carb approved (a state smog referee would), but the problem is that 99% of places will not ship or sell to a California resident if the item is not CARB approved.
The old style jerry cans for instance are not CARB approved.  Only way you can get one is get it old or one without a spout, because the spout is the problem.  I have one newer ATV style jerry can that I had to buy the spout and the tank separate just to get around the dumb rules.  There's no way around a cat that I know of though (outside of drop shipping to someone to have it re-shipped.)
« Last Edit: May 25, 2010, 10:22:34 PM by 1995yj »
« Reply #18 on: May 25, 2010, 10:48:51 PM »
The tech is supposed to look.  Although on older vehicles, it's hard to say when it was replaced.  I had a pre-CARB cat but it died and when I replaced it I just got the approved one since it's less of a hassle.  Most places will not sell you a non-approved cat.  Although I probably could have bought a 49-state cat off Amazon and had it ship OK.
« Reply #19 on: May 25, 2010, 10:51:29 PM »
Never thought to try Amazon.  Summit and Quadratec kept stopping me.  ;)
RT
« Reply #20 on: June 23, 2010, 04:06:09 PM »
so what's the labor cost of installing a high flow cat
« Reply #21 on: June 23, 2010, 04:08:07 PM »
Depends on what they charge an hour.  Although, on a YJ, it's practically DIY.  No welding involved.
« Reply #22 on: June 24, 2010, 02:12:37 AM »
Unless someone welded on the exaust before.  My stock cat was missing and a odd shapped one was welded on.  Luckily I was able to salvage my down pipe at the cat by carefully grinding away the weld and peeling back the old cat's pipe.  Then I was able to bolt on my cat and cat-back kit (minus some other set backs).
