Author Topic: Jeep HID Conversion  (Read 28239 times)
b.hog
Re: Jeep HID Conversion
« Reply #15 on: May 26, 2010, 09:52:21 AM »
For the price I paid cant beat em E bay 9.95 shipped.When I first got em they were nice and pretty and after awhile the inside has faded quite abit .On really rainy days you'll see condensation behind the glass ,and a glass reflector on the inside fell out of its housing had to epoxy it back-cheap ,but they light up way better even with 55 w bulbs then the sealed beams.The low beams on these are a hell of alot brighter then the high beam on the stock style
  • Chief Squirrel BlowerŽ
« Reply #16 on: May 26, 2010, 11:10:46 AM »
that's cheap, i'll look some more - the ones i found were about $40 to $45 shipped.
b.hog
« Reply #17 on: May 26, 2010, 11:31:49 AM »
I snagged them last minute in an auction,opening bid and nobody else bid against.The little blue lights in the bottom"city lights"they call em ,you gotta splice them in to power and ground-or leave them unhooked .Im on ebay quite a bit -window shopping-If I see some I will  :spam: ya :roflol:
« Reply #18 on: May 26, 2010, 12:49:28 PM »
yeah, or some windshield urethane sealant
i wonder if anyone used these http://cgi.ebay.com/ebaymotors/79-90-91-92-93-94-96-JEEP-CHEROKEE-EURO-HALO-HEADLIGHTS-_W0QQcmdZViewItemQQhashZitem27b203fc8eQQitemZ170490330254QQptZMotorsQ5fCarQ5fTruckQ5fPartsQ5fAccessories
and how they work compared to stock which suck a$$ for visibility at night
one think is that you can put some aftermarket bulbs in but the low beam which is the problem is usually 55 or 60 watts (from what i remember) and the high is 100 and i find that being acceptable
The only problem I can see with sealing the light up is that the heat coming off the bulb will heat up inside the housing and may cause condensation.  I'm not sure about the HID units but condensation kills Halogen bulbs pretty quick if it condenses on the bulb.  All of my Aux lights died when I was in Hawaii soon after I brought the Jeep over and needed to be replaced.  I still haven't bought new ION's for my Cebies as they are hard to find.  I know PIAA makes some but they're $60 for two bulbs.  ???
I'd be weary with those cheap Euro conversions.  I'd stick with Hella oe IPF.  Hella makes a Euro version that's not DOT as well.
« Reply #19 on: May 27, 2010, 08:35:59 AM »
i bought a set for $25 shipped and they come with 100/90w bulbs
http://cgi.ebay.com/ebaymotors/ws/eBayISAPI.dll?ViewItem&item=290437426166&ssPageName=STRK:MEWAX:IT
i'll try and purge them with argon before sealing, maybe that will keep the condensation away
cheap enough to give it a try
GBJeep
« Reply #20 on: May 27, 2010, 11:43:27 AM »
Definitely post a review on those lights.  I have seen those on ebay and have thought about giving them a try.
b.hog
« Reply #21 on: May 27, 2010, 11:47:15 AM »
right on,they look like the ones I got.
« Reply #22 on: May 27, 2010, 01:38:18 PM »
i'm also looking at a 55w hi/lo HID conversion kit at about $70 shipped but i am unsure of 1 thing
my 1995 YJ was made for Canada and therefore it has the Daytime Running Lights module in it - not sure how that would play into the matter since the Digital controllers for the HIDs would come in play there - gotta do some research before i go ahead and do the conversion.
« Reply #23 on: May 27, 2010, 02:00:39 PM »
HID will not work with DRL.
b.hog
« Reply #24 on: May 27, 2010, 03:23:13 PM »
would you get pulled over for not having the drl working?
« Reply #25 on: May 27, 2010, 03:34:44 PM »
I've read that if you wire them direct to the battery (using relays) that the stock lights get quite a bit brighter.  It seems the stock harness has high resistance and the lights don´t get the full battery voltage.
« Reply #26 on: May 27, 2010, 05:46:31 PM »
Yes they get brighter but they aren't miracle makers.  One of the problems is that the headlights are too close together which can't really be fixed.
« Last Edit: May 27, 2010, 05:47:07 PM by Jeffy »
Sine Deviance
« Reply #27 on: May 27, 2010, 10:38:49 PM »
I hate the YJ's headlights.  Frankly they are too dim at night.  I always use my PIAA Fogs (yellow filter) at night and when it's raining.  I aim my fogs down and to the right so they don't blind people too bad.
Replace the OEM lights with a set of Silverstar Ultras. They'll be plenty bright then. Mine make it look like white-blue daylight in front of me even on low-beam.
« Reply #28 on: May 27, 2010, 11:24:20 PM »
i don't think so, but can definitely use the little bulbs for that (the city driving bulbs in those lights i got) - only thing is that i need to rewire the stupid DRL.
