Author Topic: Gear for 35's  (Read 8698 times)
Re: Gear for 35's
« Reply #30 on: May 29, 2010, 08:08:03 AM »
I run 5.38 and 35" tires with my 5spd and it's awesome onroad, cruise down the interstate just fine.  Drove 2:30 hours Wednesday to the lake and got 17.75mpg, not bad for this setup. :thumb:
ya that would be a decent set up.  it's to bad dana 30/35 only take 4.88's I would have went 5.13-5.38 for 33's because I'm more of a rig we take my g/f civic for any long distance travel
you could go bigger then 5.38's and 35's if it was a dedicated trail rig
Offline TahoeYJ
Re: Gear for 35's
« Reply #31 on: May 30, 2010, 10:22:22 AM »
What RPM's do you run at on the highway at 65-70? I can't remember which manufacturers had what when I looked the other day but I found 5:29's and 5:38's for a 9"/D44 set-up, I couldn't help but think that 5:38's would run the RPM's a little high, but I try to keep mine below 3500...
Re: Gear for 35's
« Reply #32 on: May 30, 2010, 10:32:59 PM »
I run about 3000 rpms around 65mph, I know it's not excessively high.  I can hold 5th very well and accelerate good.
Re: Gear for 35's
« Reply #33 on: June 05, 2010, 11:21:51 AM »
Phil Howell (Editor of 4WD & SU Magazine) has done a 2.5L build with 5.38's as well as several others with 5.13's and they also had the Tera.  His other projects ran 35's and 5.89's.
I was just reading in this months (Aug 10) 4WD&SU Phil's 4word page 8. It's about the projects he has done that didn't work out. One of them is "the little engine that could" I am pretty sure I remember this one. It was back in the mid-late 90's. It had F9inch axles with IIRC 6.50 gears, say's in the 4word 5.60:1 something, 5 speed,Tera Low." The little engine that couldn't. It returned 10 MPG at best because my foot had to be buried to the firewall to get the Jeep to move. Bye,Bye.
I am pretty sure it had 35's since that was the largest radial at the time. If it's the one I am thinking of it was white. IIRC it was sold to a guy in Socal.
I like Phil. I like the way he writes. I have talked with him at Moab a few years ago. He has a voice that you won't forget once you hear it. It's very deep.
Re: Gear for 35's
« Reply #34 on: June 05, 2010, 04:30:12 PM »
6.50 is way too low for 35's.  It would be ok with 38's, I'm sure.  He was the editor for 4WD&SU back in the 80's.  Then he left and now he's back.
