Author Topic: My heater core died  (Read 3742 times)
Tsd
My heater core died
« on: May 30, 2010, 04:57:10 PM »
Last week I was driving home when I started to smell coolant, then i saw vapor coming out from the vents and my all my windows started to get foggy. I pulled over and checked everything and notices a big puddle of coolant on my passenger side carpet. After searching the internet it was clear that my heater core was gone so I called the stealership, they wanted to charge me 650 dollars for a new heater core. Since the original part was so expensive I had it custom made by a local shop for 90$. My new all copper heater core should be ready on Monday so I took everything apart, it was a PITA.
Here´s my Jeep´s current state:
hopefully I'll get it running again this week  :guns:.
Re: My heater core died
« Reply #1 on: May 30, 2010, 06:12:22 PM »
Heater cores are always interesting on late model vehicles.
Sine Deviance
« Reply #2 on: May 31, 2010, 02:38:10 AM »
I'm always glad I have a YJ when I see pictures like the one you posted. YJ's are just simpler.
« Reply #3 on: May 31, 2010, 09:07:06 AM »
never took the heater core off but i think you have to go thru the same ordeal for removing it on a YJ
« Reply #4 on: May 31, 2010, 12:01:43 PM »
Yup, the whole dash has to come out but it's still a little easier.
« Reply #5 on: May 31, 2010, 12:31:46 PM »
Yikes :yikes:, I would be cold for while if mine ever goes out.   :eek:
Tsd
« Reply #6 on: May 31, 2010, 03:49:21 PM »
It's not only the cold you have to live with, you would also have to live with the coolant smell, foggy windows and having to put coolant on the radiator everyday
 :beers:
« Reply #7 on: May 31, 2010, 04:36:15 PM »
Nah, that's what a 1/2" sprinker fitting and some pipe clamps would fix until my lazy butt would deal with it.  Had to patch heater hoses on the road before, so I always keep some with me.
It happened in my 1979 RV on the way to go camping 10 miles from anywhere, I used some left over 1/2" pipe I used to fix a water leak, and I was good to go.
« Reply #8 on: May 31, 2010, 07:08:01 PM »
It actually looks worse than it is the whole dash comes out fairly easy. Still takes a fair amount of time to change that silly little radiator. Gone are the days where you took out the glove box and snaked the heater core out in a jiff
« Reply #9 on: May 31, 2010, 08:04:03 PM »
That's right you guy's are in the colder months now. I always forget. How cold does it get where you are?
I hope you get it all put back together soon.
Tsd
« Reply #10 on: June 06, 2010, 04:19:23 PM »
It's not that cold. This are our averages according to The World Meteorological Organization.
 It's not very humid down here so the cold feels like refrigerator cold, and it feels a lot colder than it really is, but nothing too extreme.
I put everything together and now i have some electrical gremlins... my electrical system died while I was driving home, I think I will have to disassemble everything to find out what went wrong.  :fitz:
« Reply #11 on: June 07, 2010, 02:20:27 PM »
TSD,
No te envidio!  But before you go tearing everything apart, check the fuses; it may just turn out to be something simple!  I have to check why MY heater core keeps sending hot air when I open the vents on my YJ, and that's something I've been putting off for a while now (it wont happen for the next 3 months, as the Heep will stay in Panama until then, though).
Felipe
Tsd
« Reply #12 on: June 12, 2010, 06:05:56 PM »
TSD,
Felipe
Felipe,
I followed your advice and checked for simple things first. Turns out my battery was toast and the terminals had to be changed, thanks for saving me a lot of time!
I plan to update my alternator in the next months but before that I need to buy new battery, considering I have four 55w auxiliary lights, an 8000lb winch, gps, cell phone charger and future power inverter, how big of a battery should i get?
Thanks in advance for the advice!
« Reply #13 on: June 12, 2010, 06:43:56 PM »
Alternator size is more important than battery size so the charging system can keep up with your electrical power demands
« Reply #14 on: June 14, 2010, 09:06:31 AM »
X2!  But if you need a new battery, might as well go with an Optima.  They are not cheap, but they are well worth the $$.  The advantage is that they can take being discharged completely without dying (something the rest cannot do; now charging them back up is a bit of a pain, as you need another battery, but the battery will recover!), and they can put a lot of current in a little time (good for starting and winching).  AS for the alternator, check the FAQ for options; there are some junkyard options you can use to save some dough...
