Author Topic: Gearing for 33" tires and automatic  (Read 5787 times)
Re: Gearing for 33" tires and automatic
« Reply #15 on: June 23, 2010, 04:00:41 PM »
 4.88's would give you a advantage over me giving your auto and I'm standard.
My vote is 4.88's all the way!!
+2
« Reply #16 on: June 23, 2010, 07:31:08 PM »
for 33's and an auto, I'd go too dana 44's rear and either 5.13's or 4.88's man, those are some monster tires 4 a 4banger tho, you could probably get away with 4.56's but you're going to eat a lot of gas, what else do you have running on it?
I consistently got 15mpg w/4.56 and 35's. I don't buy it.
RT
« Reply #17 on: June 23, 2010, 10:08:23 PM »
ok, i'm sorry by my personal standards you would eat gas...if you're ok with 15 then coolio  :thumbsup:
« Reply #18 on: June 23, 2010, 10:34:49 PM »
15mpg is very respectable for 35" tires, I run 35"s and get 15-16mpg with 5.38 gears.  Who buys/builds a jeep for mileage anyway? :stick:
« Reply #19 on: June 24, 2010, 01:28:43 PM »
I get 15MPG with 4.56's and 35's but then again I tend to drive sprinted.  Hwy speeds are 70MPH so a minimum is 65MPH.  If you go slower you become a road hazard.  The biggest problem at those speeds is wind resistance.  If I slowed to 50-55MPH, I bet I could get over 18MPG.  If I drive more relaxed I can get over 16MPG.  I'm mostly doing short city driving with a few hwy stretches on the weekends so my mileage is low.  When I was doing a 40 mile commute on the hwy, I'd get 18mpg.  I also tried putting the jeep on a diet and removed a couple hundred pounds of weight but that didn't change the mileage much.  Which lead me to believe it was more about the aerodynamics of the Jeep and the wind-resistance at those higher speeds.
Going with lower gears does not necessarily mean your gas mileage will tank.  If you're running too high (numerically low), you're lugging the engine all the time and that will use more gas as well.  Keeping the engine in it's power band is more important.
Offline bootguy
« Reply #20 on: June 28, 2010, 09:44:17 PM »
3500 to 3700rpm is the sweet spot on my 2.5.  I agree with the wind resistance, since if I pull the hard top I drop 2-3 mpg.
97 TJ - I dont wave
« Reply #21 on: June 28, 2010, 09:46:01 PM »
Kia's are getting around 30mpg, I hear they take trade in's......
