Author Topic: i got a smokey one  (Read 1916 times)
greasy knuckles
i got a smokey one
« on: January 26, 2006, 02:59:46 PM »
I have a 81 cj5 with a 151 c.i. "4-banger". I had a valva job done cause it would smoke going downhill under compresion and sometime when I first start it.  Well that didnt help :(  The cylinder walls were smooth so I ruled out a broken ring.  Any help?  I also bought a Chilton's manual which said on the front cover that "Includes Vacuum Diagrams" but to my surprise not one for a 81 cj5 with a 151 c.i.  Any help?
jwrape
Smokes going downhill under compresion
« Reply #1 on: January 26, 2006, 03:54:07 PM »
Hmm, if you checked the cylinder walls while you did the vavle job, the only thing I can think of is either blow by from the PCV valve not working correctly OR your rings are bad.
Need to do a compression check and see.
