Author Topic: Dana 35c - Axle Whine  (Read 5130 times)
Re: Dana 35c - Axle Whine
« Reply #15 on: June 14, 2010, 11:30:34 PM »
http://www.quadratecforum.com/showthread.php?t=70149
Quote
Quote:
My experience has been small yoke on all YJs until 1995.
My 95 had the small yoke, newer TJs that I've worked on have had the small yoke.
The only one I've seen the larger yoke on was a 94, 4-cylinder Jeep at that.
Looks like I got the right one.  I won't know for sure until I test fit.  Can't find any authoritive answer.  Even went through the 95 XJ/YJ oem service manuals and no dice.
« Last Edit: June 14, 2010, 11:31:33 PM by 1995yj »
« Reply #16 on: June 23, 2010, 01:00:22 AM »
i thought 1995 came with 1330 in the rear (at least that's what mine had and it was the stock driveshaft and pinion yoke).
You are correct.  The 1310 was too short.  Thanks!
« Reply #17 on: June 23, 2010, 05:42:07 PM »
no prob, I have a '95 and that's what was on mine and when i replaced the d/s i had the same issue - you can buy a yoke kit with u-bolts though (that comes with the seal as they are different) and that would solve both problems (i think you mentioned wanting to convert to u-bolt style yoke
« Reply #18 on: June 24, 2010, 02:14:09 AM »
Had to go back to my local 4 wheel drive shop 2 times to get the damn u-joint right.   :brick:  I should have just listend to you and ordered the right one.  Oh, well...
