Author Topic: 2.5 engine internal year fitment  (Read 4585 times)
penske2704
« on: June 16, 2010, 11:25:58 AM »
i own a 1998 jeep tj 2.5 whit a tired engine 277 xxx km on it runs good no smoke but bad engine lifter noise ore piston knock. i iam regarding doing a rebuilt but i just wonder what year engine kit wil fit  :puzzled:  i think the engine itself it the same 1983-200?  ::)  and it is just the fuel system that is changing  .. annyway i want 030 over bore and head work whit a good cam .. is annybody can lead me witch cam should i buy whit not going nuts
tanks
Re: 2.5 engine internal year fitment
« Reply #1 on: June 18, 2010, 01:29:02 AM »
I would stick with a TJ block as it will have the same cam.  The AMC 2.5L goes all the way back to 1984.
penske2704
« Reply #2 on: June 18, 2010, 10:21:02 PM »
tanks guys
and for a cam?  were to buy  ???  here un canada  i cant not find a place were they make them  i found on other post that hesco make one but 289 $ hish .. i still look every day on e bay if i ave some luck but nop noting there  :'(
for now i iam going to buy a other complete 93 yj engine low miles whit all the cores and ax5 + t case np231 for 200$ here localy and go from there . i iam going to built this motor fresh then i got just to replace it when ready since it tis my daily
i love my 4 cyl at first i was not sure about buying that jeep but i dont regret it and whit a new engine a litle tweek ore two proper gears i know it is gona be a winner
« Reply #3 on: June 18, 2010, 11:27:57 PM »
Modified cams are only available from Clifford and Hesco.  That's it.
penske2704
« Reply #4 on: June 18, 2010, 11:38:14 PM »
connecting rod - piston - rocker arm - push rod from a 4.0  is it posible to put in a 4 cyl
penske2704
« Reply #5 on: June 21, 2010, 10:37:58 PM »
 please i need to know witch parts are interchangeble i could get good price on 4.0 rocker arm tanks
« Reply #6 on: June 23, 2010, 07:28:15 PM »
4cyl 2.5L
bore=3.875''
stroke=3.1875
piston:
compression distance=1.580''
pin dia=0.931''
6cyl 4.0L
bore=3.875''
stroke=3.414
piston:
compression distance=1.585''
pin dia=0.931''
since they are different stroke the rod length will be different compared to the 4cyl/2.5L
the compression distance is also different, the piston might work with some modifications but i can't tell for sure.
i'm pretty sure the rockers and hydraulic lifters (tappets) are the same but i have no idea if the push rod is the same length, they are quite cheap new so might as well go with the correct ones.
penske2704
« Reply #7 on: June 24, 2010, 12:16:18 AM »
tanks allot
great to ha info like that
« Reply #8 on: June 24, 2010, 12:52:43 PM »
penske2704
« Reply #9 on: June 29, 2010, 05:01:52 PM »
 :'( blown engine
whent crap today going of stop light something whent wrong in there but oil pressure was good and still good after engine started to knock like hell so il drove it home 10 km and found a other 2.5 for 300 $ running in the jeep just finish pulling it out of a 1995 yj
tonight i iam gona  pull my blown one out and prep for the new one  after i will open up the blown one a see what went wrong
will keep you inform
« Reply #10 on: June 29, 2010, 05:32:11 PM »
:'( blown engine
ouchie
good that you found a replacement, hopefully is in good shape
« Reply #11 on: June 29, 2010, 11:15:49 PM »
Clay Smith grinds the Hesco Cams....
penske2704
« Reply #12 on: July 01, 2010, 12:14:07 AM »
i finis up putting my new old engine :whistle: and went for a litle try out  -- nice smooth reving engine but i notice it was less powerfull tan my original one
maybe because it is a 95 block and i keep the red injector insted of my gray one i might go back to my gray ones i iam sure they ave more flow
by the way i open up my blown engine a found #4 piston skirt in the oil pan  :yikes: thats is what hapend  monday afternoon
« Last Edit: July 01, 2010, 12:15:09 AM by penske2704 »
« Reply #13 on: July 01, 2010, 08:03:28 AM »
'98 needs 23.2 lb/hr at 49 psi injectors, the '95 has 17.4 lb/hr at 39 psi which will only give you 19.5 lb/hr at 49 psi so you're quite short on fuel - you're way too lean so replace the injectors asap (you can damage the engine otherwise).
penske2704
« Reply #14 on: July 01, 2010, 11:38:48 AM »
tanks i iam gona doo that this afternoon  :thumbsup:
i iam also waiting for a responce from clifford for a cam they are out of stock right now but probably next week they gona ave some
but 5 model to choose from  :puzzled: witch one should i get
