Author Topic: Squeak noises in city driving  (Read 4505 times)
Re: Squeak noises in city driving
« Reply #15 on: August 06, 2010, 10:27:36 PM »
The spring must be dying as there should be enough tension to hold the hood down securely without it bouncing around while driving.
  • 4BangerJP.comŪ Donator
« Reply #16 on: August 07, 2010, 01:15:38 AM »
Probably.  I installed these "new" hood latches after I painted the thing a few years back.  Then, I thought the latches might have been knock-offs, so the spring dieing now may not be too surprising
« Last Edit: August 07, 2010, 01:16:14 AM by chrisfranklin »
« Reply #17 on: August 07, 2010, 10:28:54 AM »
I went to tj style hold downs when mine worn out
« Reply #18 on: August 07, 2010, 10:46:57 AM »
i was thinking of doing the same - saw some with a lock on them. Did you have to drill new holes?
