Author Topic: Lockers  (Read 7410 times)
callenst
Lockers
« on: February 01, 2006, 06:11:08 PM »
What lockers do you guys all run???   Pro/Con.... of each.   I am currently in the market for a locker and want to make the best investment.
TC
Lockers
« Reply #1 on: February 01, 2006, 07:27:49 PM »
Go with a manual locker.  You'll be happy and won't have to deal with any quirks.  Although, you might not want to invest anything in the Dana 35C.
SMC4WD
Lockers
« Reply #2 on: February 01, 2006, 08:17:32 PM »
Ya... D35 is not really worth investing any money into it.  So often people do very minor 4 wheeling, and aren't looking at major suspension/tire upgrades.  In that case, maybe a 'Super35' kit isn't that bad of an idea.  (Manual, just like Jeffy said!)
Another axle exchange has to do with the labor involved if it's coils.  With leaves, you weld on spring perch’s and your done.  With a coil sprung vehicle, you have to weld on coil spring plates (to exact tolerances), trac-bar brackets, upper & lower control arm brackets and maybe shock mounts and rear sway bar mounts.
The question was about lockers, but axles match lockers.  Upgrade the inners, or the whole housing…
I’m running ARB’s Front and Rear.  Ford 9” with nothing more that spring perch’s welded on.  Shock mounts are on the U-bolt skid plates.  Front is a D30 with the 30 spline inners and Ox U-joints.  Warn’s hub conversion kit finishes the ends.
ARB is Swwweeeetttt!!!
Lockers
« Reply #3 on: February 01, 2006, 08:27:28 PM »
Quote from: "SMC4WD"
That's also the sound of the air leaking out...   :wink:
Lockers
« Reply #4 on: February 01, 2006, 09:32:44 PM »
I'm running Easy up front and LockRight in the rear. I've changed my gearing to 4.88's. Since I have an auto with the 2.5l, I really don't feel any locker presence on the street. I really don't have all that power going to the rear axle. However, in slow going offroad conditions, and in low 4w, I definately do feel the lockers. I've had to relearn how to drive with a front locker. I guess me having a front ARB in a 92 Bronco got me spoiled. However, in comparison, I love the light weight and wheelbase of the TJ. LOL.
On the street, no input to the front from the front locker.
BlackYJ
Lockers
« Reply #5 on: February 02, 2006, 03:13:16 PM »
I am running ARBs front and rear and love them.  I have never had a problem with air leaks.  The front is 1 year old and the rear is 2 years old.  I really like the selectable because my Jeep is a daily driver and with Alberta winters it is really nice
SMC4WD
Lockers
« Reply #6 on: February 03, 2006, 10:48:59 PM »
Quote from: "Jeffy"
Jeffy...  Everyone loves that Pssst sound the ARB makes when the air is being released from the locker :lol:
But as far as leaks are concerned...  I won't disagee with you that some of them leak.  But most of the time, it's installation error.  OK, not all the time but most.
Finding the leak is easy when they run on 100psi.  The connections at the compressor, the connections at the axle, or inside.  If it's inside, it's usually the o-rings.  Seal housing's spin (if installed wrong) and o-rings get kinked (if installed wrong).
Spend some time on the install and and avoid any future problems...
As far as selectable lockers... there really isn't too many to choose from.  Certainly not many that are tried and true.
roadkill
Lockers
« Reply #7 on: February 03, 2006, 11:03:34 PM »
yup the Yukon 35 (same as Super 35) is what I'm running with a Detroit.  simple and no compressor, switches or airlines to worry about.  at the time I did mine there weren't near as many people offering axle assemblies ready to bolt in and the mounting brackets were harder to find.  I guess thats the downside of having a TJ.  now that theres more factory D44s to find in junkyards and more aftermarket support I probably would have went with a 44.
on to the lockers.  selectable will be just like stock for driveability.  my Detroit is only a problem when trying to make u turns or turning sharply in parking lots (makes the jeep want to buck and makes loud popping noise sometimes).  once you get used to it you can drive it where its not noticeable or you can make it pop and buck on demand.
SMC4WD
Lockers
« Reply #8 on: February 04, 2006, 10:25:48 AM »
Before I put the  9" in the back of the Jeep, I had a 'Super 35' kit and 33's...   The detroit broke once, but that was in a parking lot and was blamed on a bad cast from Detroit.  I had another one read labelled to me and it was replaced within a few days.  Labor wasn't an issue, since it was all done in house.
But my overall impression of the kit sucked.  All right, not that bad...  City driving was ok, the cheirping and banging did take some getting used to, but it was drivable.  I had to pull a small utility trailer with it...  The bang coming out of the rear scared me to death.  I thought I broke it again.
My worst scenario was on an early morning outting, where it snowed here in Western Washington.  I thought I had this bad a$$ Jeep with 33's and all these add-on's...  Well the moment I got on the freeway I was freaking out.  My rear-end was all over the place.  I was scared to go over 30 mph.  I was holding on to the steering wheel firmly with two hands, and praying that  no-one was in the lanes on either side of me.  What really got me was when this Ford Taurus zoomed by me at normal highway speeds.  Back to this thought in my head that I had a awesome Jeep, but this Taurus certainly performed better.
Since then, the 9"  upgrade, and the ARB air locker were the greatest (well another one of the greatest) upgrades I did to the Jeep.
Lockers
« Reply #9 on: February 04, 2006, 01:14:38 PM »
Hmm, you're Detroit is a lot different them mine.  I rarely hear mine.  I don't hear it through U-Turns and the only time I do is if I turn a biit right before I stop and unlock it.  Then I try to accelerate forward in 1wd and hear the one bang then I'm off.  If I shift on a turn the rear will figgle but not make any noise.  The only time I really feel newvious is when coasting down a hill where I need to be on the gas but only lightly and there is a long arc/turn in the road.  This causes the rear to lock and unlock.  You can't hear it but I can feel it.  It's a buy unerving to feel the rear end want to oversteer then stop then oversteer again and again.
roadkill
Lockers
« Reply #10 on: February 04, 2006, 02:19:14 PM »
my locker doesn't much noise either.  could be the 85/140 Lucas gear oil I'm using.  that stuff is thick and sticks to everything.  very hard to wash off if ya get it on yourself
Lockers
« Reply #11 on: February 04, 2006, 09:34:12 PM »
My Lincoln Lockers front and rear don't make any noise either.  Had them in the stock axles for a few years now and it's a daily driver and wheeled pretty hard on 33" TSL's.  Weld 'em up, you'd be surprised how reliably and driveable it is :twisted:
BlackYJ
Lockers
« Reply #12 on: February 05, 2006, 08:56:46 AM »
Quote from: "Bounty Hunter"
Lincoln lockers are only are strong as your welding, that is the major downfall.
RED_TJ
Lockers
« Reply #13 on: February 05, 2006, 10:52:17 AM »
I`m running K&S Vacuum-Locker front and rear.
Front axleshaft outer and inner 29Spline,rear K&S Fullfloaterkit 27Spline.
Lockers
« Reply #14 on: February 05, 2006, 12:59:02 PM »
Quote from: "BlackYJ"
No downfall if the welding is up to par :shock:
