Author Topic: What is this? (pics inside)  (Read 2812 times)
cvdenson
« on: August 19, 2010, 10:31:08 PM »
Can anybody tell me what this sensor is and where does the vacuum tube for it go?  It's located on the passenger side above the starter relay.
Re: What is this? (pics inside)
« Reply #1 on: August 19, 2010, 11:35:40 PM »
We could get a better idea if you zoomed out to now where you looking.  Inside cab, under hood?  Where's the other end of the hose connect?  (Snap a pic)
« Reply #2 on: August 20, 2010, 12:07:11 AM »
my best guess is a vent )maybe from the tranny or the front axle) - mine look different but i have a '95 - i can't think of anything else that would make sense since there are no wires going to it and no other hose to be a check valve
cvdenson
« Reply #3 on: August 20, 2010, 06:46:11 AM »
This sensor/relay is under the hood, on the passenger side, above the starter relay and next to the battery area on the firewall.  It is grounded and a vacuum hose is attached.  Problem is I can find anything to connect it to and if I new the name of it I could check my vacuum diagrams.
« Reply #4 on: August 20, 2010, 07:58:17 AM »
where does the other end of the hose go?
« Reply #5 on: August 20, 2010, 08:20:21 AM »
4wd indicator switch, moved to the axle on later YJ's.
« Reply #6 on: August 20, 2010, 08:57:46 AM »
wouldn't that have another wire? he says it's only 1 ground connected to it.
« Reply #7 on: August 20, 2010, 09:03:00 AM »
I doubt it's a ground wire.
« Reply #8 on: August 20, 2010, 11:12:28 AM »
x2 on the 4wd indicator switch..
« Reply #9 on: August 20, 2010, 12:35:58 PM »
 :nod:
« Last Edit: August 20, 2010, 12:36:16 PM by Jeffy »
cvdenson
« Reply #10 on: August 20, 2010, 07:05:30 PM »
The black wire you see is a ground from the switch to the firewall.
cvdenson
« Reply #11 on: August 20, 2010, 07:06:23 PM »
