Author Topic: Downshift noise?  (Read 2773 times)
lqdtrance
Downshift noise?
« on: September 21, 2010, 09:00:28 PM »
Ok, I am gonna try to describe this the best I can. Lets say that BLAAAAAHHHHHH is the sound of the exhaust then when I downshift it sounds like this BLAHHHHHH BLAAHH BLAHHH BLAAHH BLAAAAAAHHHHH. Get it? Go ahead, Flame on................
I think this means I have a leak in my exhaust correct?
Re: Downshift noise?
« Reply #1 on: September 21, 2010, 09:03:22 PM »
So it barbles?  That's normal if you have a performance exhaust.  Even a stock exhaust might do it on a downhill.
lqdtrance
« Reply #2 on: September 22, 2010, 09:40:34 PM »
No performance exhaust at all. And it does it any time I down shift or use gears to slow down. Down hill or not. I don't mind it too much but it is kind of annoying when it does it down every side street. I did just replace the muffler with another stock model. But it did this prior, just much louder due to the huge hole in the muffler.
« Reply #3 on: September 22, 2010, 10:28:39 PM »
So, you have a hole in the muffler?
« Reply #4 on: September 23, 2010, 01:10:42 AM »
Mine doesn't do it on a downshift unless I tap the gas pedal after the downshift, then it pops BLAHHH BLAHHH BLAHHH..
lqdtrance
« Reply #5 on: September 23, 2010, 04:53:18 AM »
No hole in the muffler. I just replaced the muffler. The old one had a fist sized hole.
« Reply #6 on: September 23, 2010, 08:57:15 AM »
not to worry you or anything as mine does that too (maybe not as obvious but i know exactly what you describe) - could be an injector leaking or squirting as the fuel is cut down quite a bit in engine brake
« Reply #7 on: September 23, 2010, 06:50:54 PM »
If it is the throaty BRUP BRUP BRUP coming from the exhaust, I would not be too worried; I have had it happen before and after the exhast change, the cat change, the injector change, the adjustable FPR change...  You get the idea.
lqdtrance
« Reply #8 on: September 23, 2010, 08:02:32 PM »
Ok, Cool. 1 down dozens more to go. lol
