Author Topic: 92 YJ Strip Down  (Read 7869 times)
littledavid123
92 YJ Strip Down
« on: September 30, 2010, 08:27:20 PM »
I have a 92 yj, 88,000 miles with a 2.5 that is all but blown from previous owner driving without oil. I have never done any mechanic work nor know much about it, but to date I am having a blast.
 So far I stripped the body and just this evening my buds came over and we lifted the entire body off the frame. My plans are to purchase a GM V6 and ax15 transmission from Novak with all wiring and parts. The frame has very minimal rust and will strip it down and coat with Herculiner, would prefer to do same to under body but don't know how to get the factory sprayed stuff off (any suggestions)?
I am not a rock crawler, more of a second gear cruising the mountain roads with beer cooler and a bucket of chicken...lol  I guess my second request for help would be how do I reconize wear and replacement needs for the suspension.
Any other suggestions or opinions would be appreciated. Taking my time and plan to have the project done sometime late spring.
Re: 92 YJ Strip Down
« Reply #1 on: October 01, 2010, 01:32:25 AM »
There are better products than Herc for the frame, like POR15.
Try a can of Aircraft Remover for the underbody coating, let it soak a few minutes and scrape off.  Never tried it but that'd be my first attempt.
Consider a complete 4.3L drivetrain from a donor vehicle with the 231c transfer case, you will save a lot of money on adapters.
« Reply #2 on: October 01, 2010, 09:17:55 AM »
i would just remove the factory coating where you have rust (if you do) and 1 or 2 inches around that area - use an angle grinder and a cup brush with twisted steel wires. Like Bounty suggested use POR15 or equivalent rust stop on the rust. for the rest of the underbody coating just clean well and degrease prior to spraying it. your goal is to seal the underbody well so there's no moisture forming under the coating.
for the frame best is if you can sandblast it (if you have the option) and then use cold galvanizing paint on the bare metal - use compatible paint to seal the galvanizing and then you can use herculiner or equivalent on top of that.
littledavid123
« Reply #3 on: October 01, 2010, 10:38:26 AM »
Thank You for the advice, also a note to all, 8 is exactly how many you need to remove the body in one piece (front fendors and all) it leaves 6 to hold in the air while the other 2 disengauge the stuff you didn't see or forgot...lol  I will send pics as I progress.
And to all who read...suggestions are appreciated.
littledavid123
« Reply #4 on: October 01, 2010, 04:59:36 PM »
AAAGH... I used a flare wrench to t ry to remove the brake lines from the cylinder and I rounded both nuts without budging them. What do I do from here and any suggestions on how to properly remove the other nuts from the brakes so I can sandblast the frame to paint it with POR 15?
Also I found a local guy who will sand blast (river sand) the frame, axles, steering and suspension for $150.00 price seems fair but am concerned about the river sand being to abrasive, what do the experts have to say?
« Reply #5 on: October 01, 2010, 06:02:53 PM »
Vice-grips and some liquid wrench.
« Reply #6 on: October 01, 2010, 07:52:30 PM »
... so I can sandblast the frame to paint it with POR 15?
if you sandblast it you don't need POR15 (and others chip in here if i'm wrong please). As far as i know the POR15 will seal and convert the rust so it stops the process, if it's bare metal i don't think would be more beneficial compared to an anti-rust primer, once it dries the POR15 won't convert anything.
littledavid123
« Reply #7 on: October 01, 2010, 09:13:20 PM »
Great, thanks for the help. Tomorrow the brake lines and gas tank come off and then it's to the sand blaster.
littledavid123
« Reply #8 on: October 03, 2010, 07:54:26 PM »
Shortcut
Instead of taking the brake line off the rear axle and the hoses running down to the brakes on the front end, I split an old garden hose and zip tied it around the lines prior to taking it to the sand blasters.
Also which does everyone think is best on the frame POR 15 or inorganic galvanized paint. After reading up on both it appear to me that the POR 15 would be better?
« Reply #9 on: October 03, 2010, 08:17:35 PM »
Shortcut
If money is not a problem, you could always Line-X or Rhino the frame...  That should be pretty tough!
« Reply #10 on: October 04, 2010, 12:47:30 PM »
I would not Rhino or line x the frame.  Unless you're 100% sure you got all of the rust AND sealed the whole frame, the liner will hide any rust until it's too late.  Also liners like Rhino are flammable.
My choice would be to Hammerite it or just use Rustolium Professional.
« Last Edit: October 04, 2010, 12:48:16 PM by Jeffy »
« Reply #11 on: October 04, 2010, 01:21:12 PM »
Shortcut
If it is sandblasted, go with the galvanizing paint.
« Reply #12 on: October 04, 2010, 02:43:28 PM »
that's what i said too, a bit more involved process as you need to seal it with compatible paint after though but it is the best option as far as i know.
littledavid123
« Reply #13 on: October 04, 2010, 09:45:56 PM »
Got my YJ back from the sandblaster and he did a wonderful job.
After researching everyones recomendations I am going to use the ZRC galvanizing paint, will take a total of 4 coats, 2 galvan paint and 2 topcoats but thats what the weekends are for...lol
Thanks to everyone for their inputs  :thumb: Will be back in a week or so after painting the frame with comments on the application.
littledavid123
« Reply #14 on: October 06, 2010, 08:42:32 PM »
I will try to post some pics this weekend. Another question>>> This ZRC is rather limiting as to what I can topcoat with and I need some help as to what I should topcoat with. My plans were to use Herculiner and I believe it is ok but do you folks recommend it?
