Author Topic: Still chasing the fuel leak!  (Read 3455 times)
Re: Still chasing the fuel leak!
« Reply #15 on: April 26, 2011, 12:47:34 PM »
Well, keep in mind I had to change my pump, so the gasket was changed at the time as well, and I checked it last time I took the tank down, everything looked fine.  And it is not coming from out of the filter; I have sort of located the leak to the driver's side rollover valve; it could be the fuel lines are cracked there, so I will replace those and see how it goes from there.
This kit O got had a Plate to reinforce the gasket area.
« Reply #16 on: April 26, 2011, 08:03:21 PM »
IIRC, mine had a plate as well...
